1. danlayman's Avatar
    On my Droid Bionic running ICS, my extended battery is struggling to make it 12 hours on a full chaege with light to moderate use. The battery analysis shows "Files" consuming at least 60% of the battery. Any suggestions as to why or how to stop it? Thanks in advance.
    01-23-2013 03:08 PM
  2. danrenfroe2016's Avatar
    Weird. Files does not even register on my usage... it does this even after a restart with battery pull?
    Sent from my DROID BIONIC using Android Central Forums
    01-23-2013 08:29 PM
  3. danlayman's Avatar
    I force stopped the application. Recharging now. The amount of CPU time wasn't super high but it clearly was intensively using battery resources while active. I've deleted several tuning and back-up applications. I will recharge overnight and see what happens.
    01-23-2013 08:50 PM
  1. Major battery draining
    By 6157 in forum HTC EVO 3D
    Last Post: 09-26-2012, 01:43 PM
  2. Major Battery Drain After Latest Google Maps Update?
    By jephanie in forum Verizon Galaxy Nexus
    Last Post: 08-26-2012, 10:28 AM
  3. Mobi.mgeek.tunnybrowser major battery drain
    By blade1212 in forum Droid RAZR
    Last Post: 11-18-2011, 06:08 AM
  4. "Android System" have lots of apps - cause of battery drain?
    By striders in forum Verizon HTC Thunderbolt
    Last Post: 05-13-2011, 01:48 PM
  5. Apps That Cause Unusual Battery Drain: Post Them Here
    By Air Force One in forum Verizon HTC Thunderbolt
    Last Post: 03-26-2011, 07:00 AM
