Results 1 to 7 of 7
Like Tree2Likes
  • 2 Post By Erievon
    Angry Please help me love my Bionic again...
    Hey everyone,
    I have been having issues with my Bionic ever since the upgrade to ICS including the touchscreen going non-responsive, battery drain (yes, I keep the usual battery drain suspects off, and I use Task Killer), inability to answer calls. However, the newest quirk my Bionic has been displaying, the proverbial straw, has got me thinking wistfully of getting a different phone. Perhaps you fine people can help me fix this. It has been displaying garbage in the widgets instead of text. At least right now it's displaying text for the app shortcuts, but at times everything is garbage. I was able to accomplish that after a soft reset, power cycle and battery removal.
  2. #2
    Ry
    Ry is offline
    Ry's Avatar
    Posts
    Global Posts
    4,602 Global Posts
    Default Re: Please help me love my Bionic again...
    Quote Originally Posted by Daphne Brune View Post
    Hey everyone,
    Could you post a screenshot?
    a.k.a. RyZR from HoFo
    Motorola DROID Bionic (98.72.22.XT865.Verizon.en.US, Jelly Bean 4.1.2)
    Google Nexus 7 (JDQ39, Jelly Bean 4.2.2)
    What other devices have I had? Here's my phone timeline.
    Support your favorite Android app and game developers. Pay for apps! And don't block ads!
    Here are a couple of screenshots. All widgets are displaying this behavior with text, and as I said before sometimes the app shortcuts do the same thing.
    Attached Thumbnails Attached Thumbnails Please help me love my Bionic again...-screenshot_2013-02-14-13-07-26-1-.png   Please help me love my Bionic again...-screenshot_2013-02-14-13-07-20.png
  4. #4
    Did you try a factory reset? I know it sucks, but it helped my phone a lot.
    Sent from my DROID BIONIC using Tapatalk 2
  5. #5
    Erievon's Avatar
    Posts
    Global Posts
    175 Global Posts
    +1 and then some. Agreed that it sucks, but ICS is so different from Gingerbread behind the scenes that doing the ota and then adding all that info created on the old os just creates problems. Best to start over - clean.
    Also, ditch that Task Killer. You're doing more harm then good. ICS is pretty efficient in managing itself, by you killing tasks you are fighting the OS. Just because it shows up in the task killer list doesn't mean it's truly running or draining power, just means it's in a ready state as the OS thinks it might need something from it in the near future.
    Thanked by 2:
    asmith922Ry
    doogald and Ry like this.
  6. #6
    Ry
    Ry is offline
    Ry's Avatar
    Posts
    Global Posts
    4,602 Global Posts
    Does this only happen on widgets?
  7. #7
    Use a Thunderbolt for a week... :-)
    That said - as Erievon mentioned: Uninstall Task Killer etc.
    Personally? Do a factory reset - it can be a pain but, if you back your info up - not a problem. I'm constantly playing with ROMs so I end up doing a reset every couple of months. Seems to solve many little problems. You can also try clearing the caches (Recovery menu).
    Rooting this phone (GB 893?) eliminated most of the little problems that I had with it. Now, it's running Official ICS - .246/Safestrap/CMO 10.1 JB. Since it's rooted, I can use Titanium Backup which makes recovering from a factory reset easier.
    As far as battery use - I disabled the new "Backup Assistant + Media" - (Manage apps - choose Backup Assistant + Media - uninstall updates then, disable). This helped -some. Also - I'm noticing that both of my batteries are beginning the slow downward death spiral that Lithium Ion batteries exhibit. They do have a finite service life.
  1. please help me unbrick my evo!
    By zaconuta in forum HTC EVO 4G Rooting, ROMs, and Hacks
    Last Post: 08-26-2011, 12:50 PM
  2. Please help me hate my D3 less
    By utupelo in forum Motorola Droid 3
    Last Post: 08-22-2011, 01:54 PM
  3. Please help me hate my D3 less.
    By utupelo in forum Introductions
    Last Post: 08-20-2011, 10:31 AM
  4. I like it, Now help me LOVE my galaxy tab
    By grizzylemon in forum Samsung Galaxy Tab
    Last Post: 05-12-2011, 04:58 PM
  5. Help me love my Fascinate! Notifications, keyboard, email.
    By lolreconlol in forum Verizon Fascinate
    Last Post: 10-22-2010, 12:19 PM
