1. Vampy's Avatar
    It's been so long since I've replaced a phone I'm stumped by this. Verizon just sent me a replacement Bionic because mine started to REALLY flake out. I got it all set up and apps installed without issue (and it does seem to be running smoother than my old one). My issue is when I went to restore data to some of my apps from the SD card they are telling me nothing is found. Also all the ringtones and notifications I had installed on the SD card are gone too. Is there some kind of permissions deal I need to undo to make this data visible on the new phone? My biggest concern is my Shift Worker app I use to track my work schedule and all my overtime. I had it back up to SD before I switched phones. Now, on the new phone, it's telling me there isn't any data on the SD card. When I go to the SD card in Astro most of the folders now say they are "empty" The exceptions being my Music, documents and photos in the DCIM directory. Any suggestions?
    03-28-2013 03:19 PM
  2. LDubs's Avatar
    Um I have a bad feeling you had these backed up to your internal and not external. What did you use to back them up? Are you rooted?
    sent from my icy Bionic with jellybeans on the side
    03-29-2013 07:24 PM
  3. Vampy's Avatar
    The apps did their own backups to the sd card. I even made sure the backups where there before i changed phones. I can see the folders but yhe files arent there. Same for the folders where i had my personal ringtones and notifications. I can find folders, just no files.
    Sent from my DROID BIONIC using Tapatalk 2
    03-30-2013 07:27 AM
  4. LDubs's Avatar
    Wait, apps don't make their own backups. I'm pretty sure you're confusing internal and external SD. I think you had all your stuff on internal and when you swapped devices, all gone.
    03-30-2013 09:19 AM
  5. Vampy's Avatar
    MyShiftWorker has an option in its settings to "back up data to sd card" and "restore from sd card" which i used. This wrote a data file to the sd card. I verified this. All my custom ring tones and notifications where on the sd card. I created the directories and put the files there myself via my computer when i first got the phone. Like i said, all the directories are there but the files arent.
    03-30-2013 09:41 AM
  6. LDubs's Avatar
    Hmm I'm lost then...never used that program. Sorry. I'm still thinking SD card might mean internal and not external. Did you send the old one back already?
    03-30-2013 11:03 AM
  7. Vampy's Avatar
    No...when i get home i plan to try puttung the card back in my old phone and see if they are available agaun and try moving them off to my computer. I wss just curious if thrre was some security enable i wasnt aware of that protects the files from being acccessed by another ohone
    03-30-2013 09:21 PM
  8. LDubs's Avatar
    No Sd special security. Did you get it sorted out?
    04-02-2013 08:27 PM
  9. Vampy's Avatar
    uNFORTUNATELY NO, sorry caps lock. I put the SD card back in my old phone and it couldn't see the files either. It's like when I booted up the new phone it created whole new file structure, moved the files it recognized and then deleted the rest. I even double checked my old phones internal memory and nothing was there as I kept almost everything on the SD card. So I'm baffled. I even tried putting the SD card directly in my computer...still nothing. All the directories are there, just no files in them. The "partition" that the new phone created does have a different directory structure than what was in the one I had on my old phone. Luckily it wasn't anything TOO valuable other than a couple custom ring tones and those data files for my Scheduler app.
    04-08-2013 02:47 PM
  10. LDubs's Avatar
    Wow. Weird.
    04-08-2013 06:38 PM
  1. Not showing all my space on sd card?
    By tattoomikeinnc in forum LG Optimus Elite
    Last Post: 08-12-2012, 08:55 PM
  2. Pictures not storing on SD card
    By krlombardi in forum General Help and How To
    Last Post: 09-10-2010, 03:25 PM
  3. App Uninstall - leaves folder & data on SD card?
    By jecilop in forum Android Apps
    Last Post: 07-19-2010, 09:09 AM
  4. Twitter apps that save data on SD card?
    By iChicagosports in forum Android Apps
    Last Post: 05-21-2010, 09:34 AM
  5. Music on SD card not playing...
    By TBolt in forum Verizon Droid Incredible
    Last Post: 05-01-2010, 12:55 PM
