It'd be helpful if you took a screenshot of your Battery stats in the Settings menu, preferably when it's run down for a while, so we can see what's been using up battery.
Some tips to save battery:
1. Keep the screen brightness set manually to the minimum level needed.
2. Use static wallpapers instead of live ones.
3. Keep wifi, Bluetooth, and mobile data off unless you need them. Install a good toggle app like
Power Toggles to make it easy to turn these off or on.
4. If you don't need constant web updates for your various apps, set all of the data refresh intervals for your apps (like Facebook, weather apps, news apps, etc.) to manual or to the least frequent interval available. Frequent data refreshes eat battery.
5. Turn off Location Reporting in Google Maps by opening Maps, tapping the menu button and then Settings/Location Settings, and then turning off Location Reporting. This is used primarily for Latitude, and causes Maps to execute partial wake locks many times during the day, which can drain battery.
6. Install
Wake Lock Detector and wait about a day before running it to find out which apps are causing the phone to wake up, either fully or partially, to do some kind of process. This is how I found out about #5.
7. If you don't use Google Currents, disable it. If you do, change the refresh interval to manual. Currents has been identified as a big battery hog.
8. Some antivirus/security apps use more power than others. I found that Avast used significantly more battery than Lookout.
