Results 1 to 5 of 5
    Default No LTE after Battery Swap
    All,
    My Bionic (4.1.2 Jelly Bean) was dropping service at random and suddenly losing massive amounts of battery, so I figured that I'd buy another battery. I bought one of these (because of course VZW doesn't have any batteries for them) and put it in last night, then charged it up.
    Haven't had 4G since.
    So far, I have:
    Rebooted
    Rebooted with Battery Pull
    Rebooted with Battery Pull and SIM Card Pull
    Downloaded LTE OnOff, no response when trying to go LTE Only, and 3G seems to be the best I can get.
    Thoughts? Phone is not rooted, and I have absolutely zero interest in rooting. The only thing that changed is the battery.
  2. Thread Author  Thread Author    #2
    Default Re: No LTE after Battery Swap
    For reference, I also just with no result.
    3G seems to be relatively (if that) stable, but no 4G whatsoever.
    Update: came home, put my old (OEM) battery in...4G straight from reboot.
    Is there something not in 3rd party batteries that OEM's have?
  4. #4
    Wow, that's odd for sure. I've never heard of anything like that happening. The only thing I could think of, and even this is a long shot, is if the battery wasn't able to discharge at a high enough rate to power the 4G radio. It does take extra power to run it, but I'd expect you to see other performance issues if that were the case.
    Have you swapped back and forth to replicate the issue?
  5. #5
    Motorola often uses some type of software that causes problems with non-Motorola batteries and sometimes chargers. In any event, I think your best (only choice) if you want another battery is to buy an OEM from ebay or amazon. Check reviews to make sure used or fakes aren't being sold.
    . The problem would likely be an app running in the background, or some other rogue app. I would look to find that first and delete the app, then try your original battery again, then if you are still discharging fast, buy an OEM battery from the internet.
  1. Galaxy Note 2 - Screen Mirroring disconnecting after update to 4.3
    By lejon1 in forum Android 4.1 / 4.2 / 4.3 Jelly Bean
    Last Post: 03-01-2014, 11:25 PM
  2. Galaxy S3 4.3 Upgrade - Battery / Charging Issues
    By mbressman in forum Sprint Galaxy S3
    Last Post: 02-07-2014, 12:04 PM
  3. Missing S Planner Task widget after update to 4.3
    By kfroese in forum Samsung Galaxy S3
    Last Post: 12-23-2013, 12:53 PM
  4. Galaxy s4 4.4, no signal, return to 4.3 or 4.2
    By steve song in forum Samsung Galaxy S4 Google Edition
    Last Post: 12-09-2013, 10:16 AM
  5. VZW Business - NO MotoMaker
    By evan_adams in forum Moto X
    Last Post: 12-05-2013, 09:29 PM
B
