1. xpcjx87's Avatar
    Screenshots won't pick it up so I traced it with an editor. I'm curious if its common... Not really much of a bother, just wanna know how to possibly fix it. The inside of the shape is only slightly darker than the rest of the screen, and I only see it on dark colors.
    Motorola Droid Bionic running CM 10.2.1
    06-11-2014 05:42 AM
  2. wizzrah's Avatar
    http://img.tapatalk.com/d/14/06/11/ytune3a3.jpg
    Does it happen on different ROMs? Or just the one you are currently using?
    06-11-2014 01:03 PM
  3. xpcjx87's Avatar
    It was doing it always, so it can't be the ROM.
    06-11-2014 02:53 PM
  4. wizzrah's Avatar
    Could you go in depth as to what you mean by "always"? Do you mean it happened when you got the phone brand new?
    Sent from my AT&T One XL
    06-11-2014 03:36 PM
  5. xpcjx87's Avatar
    I got it from eBay. Used. It's always been there. With stock and with official CyanogenMod so its the phone not the ROM.
    06-11-2014 03:40 PM
  6. Mooncatt's Avatar
    My guess is it's a hardware problem since it's not showing up when taking a screenshot. Not sure if it would be an LCD issue, or something else.
    06-13-2014 12:53 PM
  1. Note N7000 screen flickers and then phone dies
    By freakernic in forum Android 4.1 / 4.2 / 4.3 Jelly Bean
    Last Post: 11-27-2014, 11:06 PM
  2. Replies: 11
    Last Post: 06-23-2014, 08:58 PM
  3. Replies: 1
    Last Post: 06-11-2014, 12:05 PM
  4. Problem with WhatsApp Notification
    By shikhar10882 in forum Google Nexus 5
    Last Post: 06-11-2014, 02:59 AM
  5. S4 switching between languages problem
    By Mike Magers in forum Samsung Galaxy S4 Active
    Last Post: 06-11-2014, 02:05 AM
