Results 1 to 10 of 10
Like Tree2Likes
  • 2 Post By Landshark
    Default Hard Bricked my charge?
    Everyone,
    So I rooted and installed AB on my droid charge, but did not like it so much, so I decided to revert back to the stock rom. Anyway, in CWM I cleared everything then installed the stock rom, but when it ran it gave me an error saying the PIT file was missing. So, I found a pit file (803) and tried it again. It failed again, but after that the phone would not turn on; no recovery mode, no download mode, nothing! All I get when I charge it is the buttons on the bottom light up a bit. HELP!
    -Will
  2. #2
    Default Re: Hard Bricked my charge?
    You may be hosed. Have you tried plugging it into the computer without the battery while holding the volume-down?
  3. #3
    Default
    Pull battery and sim and sd. Hold volume down and plug phone into the computer should put you into download mode.
    Edit: didn't see above post lol.
    Sent from my SCH-I510 using Tapatalk
  4. #4
    The full odin files did not work for me. Try to use this one, it helped me recover from the same thing.
    Edit: I jumped the gun and it seemed to be the same problem I had last night. I would just give it a day or see if odin can see it without the screen coming on. Try putting it in download mode while you have odin open and see if it can see the device.
  5. #5
    all n the you have to due is flash the odin file that is on the first page when you go to forums rooting and roms it says ed2 full flash it will automatically reset your phone to stock like when you first got it just make sure you know your gmail and gmail password and your backup assitant password it tell you how to flash it basically down load the file unzip it down load odin and the drivers install the drivers the programs are all there on the odin program run it then press pda make sure you know where you put the flash file pick it then press start make sure the phone is in download mode before you start due that by pressing volume down with the power already off on the phone then connect to the computer the usb cord then the phone make sure you are holding volume down when pluging it into the phone a big yellow triagle will come up on the phone and on the odin program it should show a yellow com number in the first little box towards the left hand midlle of the odin program if it does not come on there unplug it and replug it again then press start it will due the rest for you due not unplug while it is running take care i hope this helps christo37
  6. #6
    Why not flash the EE4 full odin package with the pit file? As long as you can get odin to see your phone.
    This thread has the EE4 file and there is a link to the PIT file.
    Make sure you put the battery in after starting download mode. Seems like a lot of Charge owners need to have the battery in which was not the case for the fascinate.
    HTH
  7. #7
    ive hard bricked my phone 4 times due to bad partition files.. ONLY USE Charge.pit.. all the other ones have a GREAT chance of hard bricking your phone.. luckily i have a year manufacturers warranty on my charge and when I hard brick it I just send it in and get a new one
  8. #8
    Landshark's Avatar
    Posts
    Global Posts
    4,417 Global Posts
    ROM
    Infinity & Pool Party
    Quote Originally Posted by trentc View Post
    So what you are saying is you are committing fraud? You messed up your phone doing something which voids your warranty, then you sent it in for a warranty replacement. And what did you say happened when you sent it back for a warranty replacement? Did you tell them you hard bricked your phone when flashing a custom ROM on it? I doubt it because then you would not get a warranty replacement and would have to pay full price for the replacement. You had to lie to Samsung as to the reason it won't turn on - FRAUD. If you mess up your phone from rooting and flashing, just man up and admit you made a mistake and pay for the replacement. Warranties cover defects in the phone, not things which are your fault. I don't believe Android Central condones this type of behavior, so please don't make it seem like it's OK to get a warranty replacement for a phone YOU broke.
    Shouldn't we treat this world like the Garden of Eden and avoid the apple at all costs?
    Sometimes you go to the circus...........Sometimes the circus comes to you.
    Instructions on how to flash ROMs, Kernels, Patches, and Mods through clockworkmod recovery, CWM: DroidXcon's CWM Thread
    If you add me on Google+, please list your AC username as a nickname so I know who you are.
    Thanked by 2:
    dwitherell and Halo like this.
  9. #9
    amofiav's Avatar
    Posts
    Global Posts
    167 Global Posts
    Odin Error trying to go to stock EE4
    ID:0/005> Checking MD5 finished Sucessfully..
    <ID:0/005> Leave CS..
    <ID:0/005> SetupConnection..
    <ID:0/005> Initialzation..
    <ID:0/005> Get PIT for mapping..
    <ID:0/005> Firmware update start..
    <ID:0/005> boot.bin
    <ID:0/005>
    <ID:0/005> Complete(Write) operation failed.
    <ID:0/005> Removed!!
    <OSM> All threads completed. (succeed 0 / failed 1)
    i had AB5 that was running fine. I decided to try out the Infinity (which loaded fine). I didnt like it so I tried to go back to stock EE4 unsuccessfully. If I can get back to stock I can work from there or AB4 or AB5.
    **update**
    I was able to get my phone booted with a stock EE4. I was able to OTA to EP4 and will decide on Rooting with GB or going back to AB5.
  10. #10
    cmarks03's Avatar
    Posts
    ROM
    Rooted Debloated Stock
    Quote Originally Posted by wnschmidt View Post
    Everyone,
    -Will
    Fortunately I don't have any experience with this type of situation (knock on wood). What I have found in searching out of curiosity is that you folks have figured out how to recover bricked phones via JTAG. I haven't tried these guys, and I'm not affiliated with them in any way, but there is this:
    And a YouTube video talking about the procedure:
    They charge $50 to recover the Charge, but that's a heck of a lot cheaper than hundreds for a new phone off contract.
    Chris
