Results 1 to 14 of 14
Like Tree2Likes
  • 1 Post By piizzadude
    Default questions for the experts
    im about to root my phone. this phone is slow as hell just straight out of the box.
    after reading many guides for dummies , it seems the only thing holding me back is the terms used.
    you guys use words that confused people ROM...FLASH...ODIN....KERNEL ETC
    root from my understanding is just gaining exclusive access to your phone. basically gaining administrative rights i got that covered.
    what is a ROM?
    what is to FLASH?
    WHAT IS A KERNEL? and do i need a kernel ?
    is ODIN the PC program used similar to BB desktop manager when upgrading BB OS.
    what is CWM? and what is its purpose?
    sorry for all these questions BUT A GLOSSARY IS REALLY NEEDED. i think thats what holding alot of people from rotoing.
  2. #2
    piizzadude's Avatar
    Banned
    Posts
    Global Posts
    5,774 Global Posts
    ROM
    Something JB
    Default Re: questions for the experts
    what is a ROM?
    A ROM is basically the Android OS customized to our phone. it is the software behind the hardware
    what is to FLASH?
    Flashing is how we put the ROM on the phone
    The Kernel is the little piece of software that gives all the orders to all the other pieces of software on your phone. It is responsible for all the function of your phone and keep everything in line. look at it as an organizer. You hit the phone button, the kernel realizes that was pushed and tells the dialer.apk to put the keypad up. Yes you need one, most roms come with one and you can swicth them out by flashing a different one
    ODIN is like BB manager in the sense that you can flash upgrades and ROMs with it. it is a simple program but remember, whenever you flash anything, use the PDA button not the PHONE button
    CWM is like ODIN for your phone. You can flash ROMS and Themes with it but do a bit more. You can wipe data (if there is a corruption) reset some things and backup your phone before you flash a ROM so that if the flash fails the first time or hate the theme or ROM, you can go right back to where you were
    Thanked by 3:
    JhettDark likes this.
  3. #3
    piizzadude's Avatar
    Banned
    Posts
    Global Posts
    5,774 Global Posts
    ROM
    Something JB
    BTW: There is a dictionary. Check the stickies in this section: http://forums.androidcentral.com/general-help-how/
  4. #4
    deadpenguins's Avatar
    Posts
    ROM
    GummyCHARGED FE 2.0
    piizzadude gave a great response . I was ready to chime in but he gave some of the best rooting 101 for terminology you can ask for. I remember when I first got my android (only a couple months ago) and I was terrified to break the most beautiful thing I've owned, but took the plunge using the How to Root EE4 thread and was done in 20 mins. Granted I've done major tinkering and tweaking since that day, but after a while it becomes very natural.
    My best word of advice. Look for answers. If you're unsure, ask questions. Reading a thread of rooting can be very intimidating, but as long as you are meticulous and can carefully follow instructions, you will understand the beauty and power of the root world. Good luck and welcome!
  5. #5
    Landshark's Avatar
    Posts
    Global Posts
    4,417 Global Posts
    ROM
    Infinity & Pool Party
    This was written by Sheepdog Elite for the Fascinate, but the terms are all the same as the Charge is almost like a bigger Fascinate on 4G:
    http://forum.androidcentral.com/veri...3-17-11-a.html
    Shouldn't we treat this world like the Garden of Eden and avoid the apple at all costs?
    Sometimes you go to the circus...........Sometimes the circus comes to you.
    Instructions on how to flash ROMs, Kernels, Patches, and Mods through clockworkmod recovery, CWM: DroidXcon's CWM Thread
    If you add me on Google+, please list your AC username as a nickname so I know who you are.
  6. #6
    piizzadude's Avatar
    Banned
    Posts
    Global Posts
    5,774 Global Posts
    ROM
    Something JB
    forgot all about that one....
  7. #7
    Landshark's Avatar
    Posts
    Global Posts
    4,417 Global Posts
    ROM
    Quote Originally Posted by piizzadude View Post
    Rainman memory. Plus we're all a team here working together. Reminds me I haven't talked to him in a while, need to reach out.
  8. #8
    piizzadude's Avatar
    Banned
    Posts
    Global Posts
    5,774 Global Posts
    ROM
    Something JB
    Yeah I havent seen much of you guys since I do not hang out in the fassy forums anymore...
  9. #9
    Landshark's Avatar
    Posts
    Global Posts
    4,417 Global Posts
    ROM
    I'm splitting my time between the Fassy and the Charge since I have both right now. Sometimes it's tough to keep up. I see you've done a great job picking up a lot of the slack here in the Charge forum. Thanks for all your help.
  10. #10
    piizzadude's Avatar
    Banned
    Posts
    Global Posts
    5,774 Global Posts
    ROM
    Something JB
    Hey it is all thanks to what you guys taught me over there. There really isnt much over here outside the usual. I expect that will change with GB.
    Thank you for all you do around here.
    Thanked by:
  11. Thread Author  Thread Author    #11
    so i took the plunge and rooted.
    i installed thiss>>CI510_VZW_EP1W_ALL_ONE-LTE-CP_REV3_user_CL485836_ship_rooted.tar
    which is the latest gingerbread bloated rooted leak.
    everything went smooth. is there anyway i can replace the battery indicator ontop and put a percentage instead. i dont want an app or widget .. i just want to replace without losing screen real state.
  12. #12
    piizzadude's Avatar
    Banned
    Posts
    Global Posts
    5,774 Global Posts
    ROM
    Something JB
    how far do you want to go with it? The only way I know to do it with UOT (a theme kitchen) but I havent looked at it with the GB leak. Do a search on XDA for UOT for more info
  13. Thread Author  Thread Author    #13
    Default
    Cool thanks
    Sent from my SCH-I510 using Tapatalk
  14. Thread Author  Thread Author    #14
    Default
    Do i need to flash the new modem/radio or is it included already?
