Page 2 of 2 FirstFirst 12
Results 26 to 40 of 40
  1. #26
    Stang68's Avatar
    Posts
    Global Posts
    5,130 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    So a 1526 in Quadrant means VooDoo is enabled?
  2. Thread Author  Thread Author    #27
    gunnermike53's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Gummy, AOKP
    Default
    Quote Originally Posted by Stang68 View Post
    Qudarent is stupid. Follow the instructions on how to check for voodoo. I can make my quadrent scores 6000 on rfs.
    Sent from my SCH-I500 using Tapatalk
    Stang68 likes this.
  3. #28
    billku's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    Is there an update for this yet, or are we still using the CWM where the go back/menu key doesn't work?
  4. #29
    DawgPoundMBA's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    Quote Originally Posted by billku View Post
    I installed the update, which it says was successful, but then I couldnt go back so I unplugged the battery. Am I at 4.1 or just 4.0 now?
  5. #30
    neemo6's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    With phone off, I hold volume up + home + nd power buttons and all i get is the samsung screen logo nothing more. What could be wrong
  6. #31
    rescueswimmer's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Altered Beast V4
    Default
    Did you flash something? If you did and its vodoo it will hang there for a 2-7 minutes converting your file system. If you flashed something and it hangs like that for 10 minutes. If it converted files to ext4,(vodoo) you will need to flash another vodoo kernel then disable the lagfix. Then you need to go back to odin and flash the Ed1 stock rom and go from there. make sure after you flash the stock rom you wipe the caches etc.
    RS
  7. #32
    hooskins's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    EE4/Gummy 1.8.1/PBJT
    Default
    can someone explain the difference between the different color cwm's? I have a yellow one. I think its yellow bc its a voodoo one or is it bc of the version?
    Also im pretty voodoo is enabled for me(1500 quadrent score) but im trying to make sure from cwm. It says its disabled but im able use the voodoo control app?
  8. #33
    hooskins's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Default
    Also, what's the difference between the different types of caches? I didn't clear any of them while rooting.
  9. #34
    hooskins's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Default
    Quote Originally Posted by hooskins View Post
    Bump on my questions. I got the voodoo enabled one answered, but unsure about the rest. Thanks.
  10. #35
    T-Rob's Avatar
    Posts
    Global Posts
    371 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: [How To] Using CWM and Voodoo June, 5 2011
    Gunnermike...got a question. Just switched over the the D1...things are a bit different with the Charge. I just finished rooting my phone and did everything I was supposed to do...even verified through the Terminal Emulator that I'm running the voodoo kernal...BUT, when I got into CWM and go to Voodoo, it shows the following:
    CWM Voodoo Lagfix Recovery v4.0.0.1
    Voodoo lagfix is actually: disabled
    next boot: disabled
    Options:
    /system lagfix conversion: no
    debug mode: no
    Can you explain this to me? Did I do something wrong?
    Thanks,
    T
  11. #36
    zombiebot's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    AOKP
    Quote Originally Posted by T_Rob View Post
    next boot: disabled
    Options:
    debug mode: no
    Thanks,
    T
    If you look at imnuts CWM thread, he states that:
    'Voodoo Lagfix status is not properly read from Recovery, use "adb mount" to verify your lagfix status'
    Probably something being worked on.
  12. #37
    s14tat's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    AOKP ICS build 38
    Does the charge have a fully functioning nandroid back up yet? If not what have you guys been using for back up?
  13. #38
    Toniojonesw's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    i haved downloade the alter beast alpha but my camera doesnt work nor does the home button and my gallery. Can u tell me if it is something Im doing wrong.
  14. #39
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: How to unVoodoo
    hello i downloded the alster beast alpha for my droid charge but i cnat get the camera home button or the gallery to work. can someone plz tell me what it is that i am doing wrong.
  15. #40
    dgoralski's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Hi installed the altered beast zip went to reboot system when done. Phone seems to be stuck in the samsung logo loop. Any suggestions? Thanks
