Mac2112
updated with more voodoo stuff
Hey bro I opened cwm made sure voodoo lagfix was enabled then opened connectbot typed mount it said rfs instead of ex4 am I doing some thing wrong i'm deff a noob at this any help appreciated
are you sure you flashed a voodoo kernel
Not sure I flashed stock ed1root then ab4
So a 1526 in Quadrant means VooDoo is enabled?
Is there an update for this yet, or are we still using the CWM where the go back/menu key doesn't work?
Also, what's the difference between the different types of caches? I didn't clear any of them while rooting.
Gunnermike...got a question. Just switched over the the D1...things are a bit different with the Charge. I just finished rooting my phone and did everything I was supposed to do...even verified through the Terminal Emulator that I'm running the voodoo kernal...BUT, when I got into CWM and go to Voodoo, it shows the following:
CWM Voodoo Lagfix Recovery v4.0.0.1
Voodoo lagfix is actually: disabled
next boot: disabled
Options:
/system lagfix conversion: no
debug mode: no
Can you explain this to me? Did I do something wrong?
Thanks,
T
