H Harreh Well-known member Nov 29, 2010 73 3 0 Jul 2, 2011 #21 AirSushi said: Are you rooted? If you are not rooted use the included Verizon mobile hotspot app. Your tablet will pick up the wifi signal. Sent from my SCH-I510 using Tapatalk Click to expand... Right, but there will be a charge after the 7th.
A AirSushi Active member Jan 25, 2011 38 4 0 Jul 6, 2011 #22 Ok I rooted my Charge this last weekend. You are right that both Barnacle and OpenGarden do not work tethering two android devices. See the article here. szym.net ? Ad-hoc Wifi in Android It is very odd that both the Verizon hotspot application that comes pre-installed the Charge will tether two android devices without issues. Unsure as to what to do now as I do not know how to compile code.
