[ROM][EE4] GummyCHARGED 1.8 6/22/2011
rescueswimmer
184
26
I used this and flashed it over ab4 in odin, i am having issues getting jt's rom to flash but it worked, flashed back to ab4 because i could not find the settings tab for launchr pro
Sent from my SCH-I510 using Tapatalk
Nash Latkje
12
Toying with trying out Gummy since you've got the ee4 update going now.
Quick questions
Already running AB4.1.1 and I haven't installed ee4 at all. Will flashing to Gummy install e4 or will I need to flash stock and OTA for it first?
kejar31
Active member
Dec 30, 2010
36
32
Quick questions
Here is the quick and dirty instructions on going from a rooted ED2 install to a Rooted EE4 with GummyCharged
1. Install ED1 Root Odin found here on XDA (make sure you deactivate voodoo if you have it activated)
2. Boot and let it OTA you to ED2 (stock)
3. download the EE4 update found on this site and put it on the root of your SD card.. Rename that file to update.zip
4. boot into stock recovery and select install update.zip.
5. let it do its thing
6. after booting and verifying that everything is working on EE4, install CWR from this thread via Odin
7. Install a root Kernel via Odin or CWR for either voodoo or non voodoo depending on whether you want or know how to activate it.
8. install Wipe data
9. Install GummyCharged
Nash Latkje
12
Decided to be ******ed and stay up to do this.
>.>; -edit- Did the smart things and double backed in the thread...
After WAY to long I have Gummy on my charge. I'll post opinions on it when I've had time to play with it tomorrow.
-_-; for some reason my phone would not flash CWM after i messed up the first time. Had to reinstall AB to get the kernel to install properly...
reflekt2099
223
70
has anyone had any problems getting their contacts backed up after installing gummycharge (since it requires to do a wipe data/factory reset)???
backup assistant won't work. and i really need to get my contacts back.
when i try to run backup assistant, i keep getting "android.process.acore has stopped unexpectedly. Please try again"
muzhik
101
4
did u have them backed up to ur google account by any chance?
Posted from AB 4.1.1 using Tapatalk
Chelrie
