Results 1 to 3 of 3
    jpoy808's Avatar
    Posts
    Carrier
    stock
    Default custom rom charge question
    I installed gummycharged rom 1.85 and voodoo fix on wife's charge, wanted to install altered beast alpha rom, do I disable voodoo lag fix first or can I just flash through cwm? Also if I wanted to go back to stock do I just flash the modem ed2 stock package via odin ? Do I have to diable lag fix first or any suggestions.
  2. #2
    Harreh's Avatar
    Posts
    Global Posts
    152 Global Posts
    Carrier
    Abeast v4
    Default
    I just came from Ab v5 to Gummycharged 1.8. 5 using the voodoo kernal. Just flashed the rom in cwm.
    Sent from my SCH-I510 using Tapatalk
    jpoy808's Avatar
    Posts
    Carrier
    stock
    Default Re: custom rom charge question
    did you notice anything different from alterbeast and gummycharged? which do you like better?
