Results 1 to 10 of 10
- 10-26-2012, 10:25 AM
Thread Author #1
Flip stand problem
So I purchased the flip stand a couple days ago and the first day it worked perfectly. The second however, each time I plugged it in I just got a error message saying 'Unfortunately, the smart dock has stopped'. This only happens when I select the Bedside mode. The office and clock modes still work fine. Any ideas?
- 10-26-2012, 10:31 AM #2
Re: Flip stand problem
Maybe a factory reset. I know you don't want to but I've never had this happen before
Sent from my DROID RAZR MAXX HD using Tapatalk 2 - 10-26-2012, 03:46 PM
Thread Author #3
- 10-29-2012, 11:37 AM
Thread Author #4
- 10-30-2012, 05:54 AM #5
- 10-30-2012, 11:25 AM
Thread Author #6
- 10-31-2012, 06:37 PM #7
I have just finished a conversation with Motorola Tech Support Level 3. The problem is a conflict between Google Play Music and the Dock Application in the Bedside mode. When you have a Music album selected in Google Play Music the Bedside Dock mode will crash. To fix the problem go to Setting/Applications/All and select Google Play Music. Reset the application by uninsalling updates or by clearing data to zero. This removes the albums you have selected from the play application. If albums are still shown in the google play application go to another page and come back this should cancel the albums. The play application should not show any albums selected. Dock function should now work in Bedside mode.
- 12-10-2012, 10:50 AM #8
I'm not sure this is entirely accurate, but you helped me launch the dock application successfully.
It's definitely a conflict with Google Play Music, but it may not be having an album selected that's the problem. I just encountered the issue for the first time, and after reading your post, I realized that I had deleted some MP3's stored locally on my SD Card. Just as a test, I went into Google Play Music, and selected an album and started playing a track, then paused. I then tried to launch the bedside dock and it worked.
BTW, I have the Atrix HD which is essentially AT&T's version of the RAZR.
- 12-10-2012, 03:05 PM #9
- 12-12-2012, 10:33 AM #10
The workaround I found is to delete the updates for Google Play Music. Then install another music playing app. Go into the dock and choose that app as the default music player. Then load the updates for Google Music again. The downside is any time you play a song it will cause the dock to lock up again. To stop this you have to go into Music and clear the now playing queue. This is the only way I've found to still have my music cached and also be able to use the dock. Matt over at the Motorola forums has stated that Motorola is working on a fix for the issue.
Motorola Flip Stand
By Eclipse2K in forum Droid RAZR MAXX HDReplies: 4Last Post: 10-18-2012, 11:30 PM -
Flip Clock/Weather widget problem
By cycophuk in forum HTC HeroReplies: 0Last Post: 01-06-2010, 01:54 PM -
Sprint Hero has text messaging problem!
By maxfire05#ac in forum HTC HeroReplies: 10Last Post: 10-10-2009, 10:49 AM -
FreeRunner cupcake... teething problems
By Thorney in forum General Help and How ToReplies: 1Last Post: 09-05-2009, 12:41 AM -
problem with google sign in: password not valid
By sonali in forum T-Mobile G1Replies: 2Last Post: 06-20-2009, 10:39 AM
Reply
