Results 1 to 2 of 2
    Default Help re: SD card
    I'm new to the Razr HD, having abandoned my Thunderbolt. With the T-bolt, I had an app called Apps 2 SD, which transferred data from the phone memory to the SD card. I've tried several versions of this on the Razr, but none will work. I'm aware of "Manage Internal Storage" in Storage in Settings, for moving pictures, movies and songs to the SD card, and that works. But how do you back up data on the SD card for safety, if I need to do a factory reset for example? If anybody has figured this out, please let me know, because I like the Razr HD very much and don't want to return it.
    Thanks.
  2. #2
    shadofall's Avatar
    Posts
    Global Posts
    49 Global Posts
    Default Re: Help re: SD card
    if i'm correct, this is a limitation of ICS and requires root to get around.
  1. please help - lost sd card pics
    By thedonjl in forum HTC EVO 3D
    Last Post: 07-16-2011, 11:49 PM
  2. Help with SD card
    By kufta4 in forum General Help and How To
    Last Post: 03-23-2011, 08:16 AM
  3. help with sd card on htc hero sprint...
    By kkimble1986 in forum General Help and How To
    Last Post: 03-07-2011, 01:05 PM
  4. Help changing sd card
    By jespl629 in forum General Help and How To
    Last Post: 02-06-2011, 09:58 PM
  5. HELP!! Lost SD card and all nandroid backups, now stuck in boot loop
    By handbra#ac in forum Incredible Rooting, ROMs, and Hacks
    Last Post: 09-22-2010, 09:24 AM
