Results 1 to 16 of 16
Like Tree1Likes
  • 1 Post By kaylamarie91110
  • 1 Post By B. Diddy
  • 1 Post By prolongExistence
    kaylamarie91110's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default The vibrate mode on my phone will not work
    My phone will not vibrate on vibrate mode. It will not vibrate on the sound mode (which is what I have it set on). When i get a text or notification it has to be on full volume to make a sound or silent. It will not vibrate at all, not for a call or for a text.
  2. #2
    B. Diddy's Avatar
    Posts
    Global Posts
    78,110 Global Posts
    Mentioned
    6 Post(s)
    Tagged
    0 Thread(s)
    Default Re: The vibrate mode on my phone will not work
    Welcome to Android Central! Does it ever vibrate? Like if you power off completely, then power back on, phones that can vibrate will usually vibrate once as you see the bootscreen appear.
    Or how about the keyboard? Does the vibration work with each keypress if you have that setting turned on?
    If none of these work, then it is likely that the vibration motor is broken. Remember that it's essentially the only moving part inside the phone, so it's not surprising that it is prone to breakdown.
    mm12b004 likes this.
  3. #3
    prolongExistence's Avatar
    Posts
    Global Posts
    801 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I agree with B. Diddy, sounds like the motor is shot. Here's a nice app to test all the "bells and whistles" of your phone...
    https://play.google.com/store/apps/d...an.zdevicetest
    B. Diddy likes this.
  4. #4
    mm12b004's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    how much does it cost to repair the vibrate motor.
  5. #5
    B. Diddy's Avatar
    Posts
    Global Posts
    78,110 Global Posts
    Mentioned
    6 Post(s)
    Tagged
    0 Thread(s)
    Welcome to Android Central! I suggest you call up a cellphone repair shop and ask them for the general price range.
  6. #6
    Deepak Tiwari3's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by B. Diddy View Post
    Hey I checked out the app the other guy suggested and it shows a check mark for vibrator..what should I do yo check if the motor's working or not?
  7. #7
    Posts
    Global Posts
    801 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Hi. "other guy" here. If you actually tap the check mark then it will open to another screen where you can force the vibrator to vibrate. The check marks are just there on the menu screen to tell you which tests are compatible with your particular device.
  8. #8
    raghav mamidala's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    In Samsung service centre, the vibrator motor costs 400/- and its warranty is 1month and for the service they charge 150/-.
    In my case the problem is much severe and the engineer said that they need to retrack the connections, for that they charged 400/-
  9. #9
    dilip76's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    please resolve my problem
  10. #10
    dilip76's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    The vibrate mode on my phone will not working
  11. #11
    krd1433's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    My phone vibrates whenever I get a email and when I tap the keys on the keyboard but when I get a text message or a notification it will not vibrate. I reset my phone and it started vibrating again, and then it all of a sudden stopped vibrating whenever I got a notification. How can I fix it?
  12. #12
    anukul6119's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Dude my vibrant didn't work while clicked on the vibration button... Is that mean that my vibration motor is dead
  13. #13
    Elizabeth636's Avatar
    Posts
    Global Posts
    2 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by raghav mamidala View Post
    Isn't that a bit excessive? I payed around 250 for my phone... I might as well just spend that money on a newer, better device.
  14. #14
    Anthopare16's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by anukul6119 View Post
    Go under Settings -> Sounds and Vibrations -> Vibration intensity -> put notification the level you want.
    My phone change this setting sometime for no reason... Weird :X
    OhtNa
  15. #15
    Raja Azim1's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by Anthopare16 View Post
    OhtNa
    I cant find it
  16. #16
    NepRitesh's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by Elizabeth636 View Post
    Actually he is talking about Indian currency. Which is relatively 1$=68rupees. 400 means 6$
  1. Does weaker - but not no/barely any - signal still affect battery life?
    By icouldntpossiblycomment in forum Samsung Galaxy S5
    Last Post: 09-09-2015, 03:18 PM
  2. [ROM Review] Carbon for the HTC M8
    By Golfdriver97 in forum HTC One M8 Rooting, ROMs, & Hacks
    Last Post: 08-07-2014, 11:23 PM
  3. Deleted OS on Galaxy s3
    By bonillaaa in forum Sprint Galaxy S3 Rooting, ROMs, and Hacks
    Last Post: 06-13-2014, 12:45 PM
  4. White color on my Nexus 7 2013 screen not perfectly even!!Is this normal?
    By Aditya Shanbhag1 in forum Google Nexus 7 Tablet (2013)
    Last Post: 06-11-2014, 08:28 PM
