First post, so first off: Greetings!
So! I bought the Razr M a couple of weeks ago, just prior to the JB update. Had no issues with the phone prior. After the update, however, I ran into a few problems:
1. External Storage doesn't seem to be read properly. My Pictures folder on my card is populated with 96 pictures, although the Gallery app only displays 50 (but I can still view the other 46 pictures in the files browser). Also, I'm unable to assign any ringtones directly from my SD card in Sound settings. Yet when copied to internal storage, the phone will display my ringtones in Sound settings and allow me to assign them.
2. I have not been able to select "USB mass storage" for the USB connection settings since the update. Has this feature been omitted?
3. Though this isn't an issue, per se, I've noticed that the sound effects and equalizer in the Sound settings are no longer available since the update. I'm content without them, but was just wondering if they are suppose to still show up in 4.1.
Bear in mind that I have done a factory reset, as well as reformatted my microSD card, and these problems continue to persist. The only issue the factory reset fixed was with my smart actions (they would not save any alterations I made to the triggers nor actions).
I'm still under the store's return policy, and I'm strongly considering doing an even exchange. Although, if they have extended their deal on the SIII, I MAY just swap the M for it. Anyone keen on a fix? Or does anyone know what is causing these problems? And any opinions on swapping out my M for an SIII are appreciated as well.
