Results 1 to 10 of 10
Like Tree1Likes
  • 1 Post By Jeff Da
    Default More battery life
    I was wondering what I can do to increase battery life. I have been using my RAZR m a lot today but I went from a full charge to now 40% without using any taxing apps. I've only had data and WiFi on today and even if they drain a lot of power a cell phone shouldn't be going this fast I think. I'm going to let the battery run to 0% and see if that helps.
  2. Thread Author  Thread Author    #2
    Default Re: More battery life
    Okay I've let the battery run down to auto shut down and I've disabled the Verizon sync service bloatware so I'm hoping that that will help a lot in battery life.
    Anyone have any ideas for better battery life?
    Running the battery until 0% didn't help, one hour still took about 4% out of the charge. I don't know how people are claiming a few days on one charge while using their phone all day while they have WiFi, data and maybe even Bluetooth going, I can't get even one day off of a full charge!
    I've disabled Verizon sync, Facebook sync, display is at 50%. I do have WiFi and data on but when the phone is in stand by the WiFi should turn off right?
    If anyone has any ideas I'd love to hear them because I'm out of my own.
  4. #4
    dki378's Avatar
    Posts
    Global Posts
    97 Global Posts
    Quote Originally Posted by Jeff Da View Post
    Which Verizon sync service are you talking about? I still have a very cloudy understanding on what sync services are active on my phone and would like to disable this as well. Thanks.
    It's just called sync service, it's icon is just a red square with a cloud in it. It will keep the backup services from Verizon from starting but it will disable my verizon . I don't think that I'll use that often if at all so it doesn't matter that much to me. Google sync isn't affected with disabling the Verizon sync. I only want Google sync which I sat on manual so I'm good.
    Thanked by:
    dki378
  6. #6
    I've only had this phone a few days, but for me the battery has been much better than others (blows the gnex out of the water). I've been getting through a full day with ease and use the phone quite a bit. One thing I'll note, I never have the screen higher than around 20-25%. The screen definitely uses quite a bit of juice so the lower you can use it comfortably the better battery life you'll see.
    When I disabled the Verizon backup thing I saw a HUGE increase in battery life as well, to me at least, my phone seems a little faster too. I don't like bloatware which Verizon loads their phones with and I hate when it's made to where I can't remove or at least disable it.
    Thanked by:
    DeputyBob likes this.
  8. #8
    What is this Verizon Backup/sync service thingy, you speak of?
    I cannot seem to find it.
    Verizon back up thing does about the same thing as Google backup. It can be found under the all tab in the apps menu. You can't remove it but you can disable it.
  10. #10
    You can save a tiny bit more battery by having a black screensaver.
    Sent from my XT907 using Android Central Forums
  1. Battery life terrible?
    By bilobi in forum T-Mobile G1
    Last Post: 04-02-2013, 01:48 PM
  2. More awful vivid battery life.
    By jayjay1o1 in forum HTC Vivid
    Last Post: 12-10-2012, 03:33 PM
  3. Sprint lovers rom with more freedom kernal battery life
    By Dark_Majesty_06 in forum HTC EVO 4G Rooting, ROMs, and Hacks
    Last Post: 08-27-2011, 03:23 PM
  4. Root = More Battery Life?
    By js2393 in forum HTC EVO 4G Rooting, ROMs, and Hacks
    Last Post: 07-17-2010, 01:11 PM
  5. Replies: 52
    Last Post: 07-13-2010, 03:27 PM
