Results 1 to 5 of 5
- 12-21-2012, 01:04 PM
Thread Author #1
- 12-21-2012, 01:34 PM #2
Re: Wifi disconnecting randomly quite a bit
My RAZR M was having a lot of problems connecting to WiFi when I first got it. But it was only mine, it connected to everyone else's with no problem. I had to change my router from WAP to WEP. Its less security, but it connected immediately. I can't tell you why, I just know it works. I think I'll have to get a new router because I'm nervous about the security. Not sure if this will help you or not, but it worked for me.
Sent from my XT907 using Android Central Forums - 02-03-2013, 06:19 AM #3
Mine to. First RAZR m would drain 3% overnight, this new one will drain 40% over night do to the constant dropping and switching to 4G. Any fix?
Sent from my XT907 using Tapatalk 2 - 02-03-2013, 08:24 AM #4
I had that happen whenever I was on the other side of the house from my router, but fixed it in my wifi settings. When on the wifi screen in settings I hit the menu button (three dots on the bottom right). I choose "advanced". The setting for "Avoid poor connections" was checked by default. I have never had a problem with it since I unchecked that setting.
Sent from my Xoom using Tapatalk 2You can observe a lot by watching- Yogi Berra - 02-05-2013, 09:17 PM #5
Yup I have that unchecked as well and still have issues. Verizon is sending me a certified like new phone, so will see if that corrects my problem.
Droid X2 WiFi disconnects randomly after update
By tlk in forum Motorola Droid X2Replies: 11Last Post: 06-13-2012, 10:22 PM -
WiFi disconnects call
By southerngirl1913 in forum HTC EVO 3DReplies: 8Last Post: 07-31-2011, 10:38 PM -
Wifi disconnect loop on atrix
By crnkoj in forum AT&T ATRIXReplies: 0Last Post: 03-04-2011, 05:39 PM -
wifi disconnects
By prubin99 in forum HTC EVO 4GReplies: 2Last Post: 12-23-2010, 11:06 PM -
Google Listen Randomly Quits
By sethjk in forum Android ApplicationsReplies: 6Last Post: 06-13-2010, 11:56 AM
Reply
