Results 1 to 9 of 9
Like Tree1Likes
  • 1 Post By dpham00
    Exclamation Droid Razr M WILL NOT CHARGE
    Okay so i recently charged my phone (overnight) and woke up around 1pm after it being on the charger for atleast a minimum of 12 hours, i took it off and got a shower ect. when i went out for dinner i used my gps and 4G and it almost completely drained it. I have snapdragon on it and it does a excellent job of maintaining battery life, i then got home and proceeded to charge it only to have it shut off and turn back on constantly for 3 hours. I do wash it atleast once a week and hand dry it completely, although it has never been affected at all. I need some help on this, i've stressed all my options and i've got work in the morning and i really need my phone for work..
    All Responses Welcome, Thank you
  2. #2
    wizzrah's Avatar
    Posts
    Global Posts
    4,726 Global Posts
    Carrier
    Kitkat
    Default Re: Droid Razr M WILL NOT CHARGE
    Quote Originally Posted by I_SHeet_MIDGETs View Post
    So when you connect it, it doesn't charge at all?
    Quote Originally Posted by wizzrah View Post
    You Are Correct
  4. #4
    Maybe try a different cable and charger?
    dpham00, Android Central Moderator
    Sent from my Verizon Samsung Galaxy Note 3 via Tapatalk Pro
  5. #5
    wizzrah's Avatar
    Posts
    Global Posts
    4,726 Global Posts
    Carrier
    Kitkat
    You Are Correct
    It could be the charger or cable like dpham said. It could also be the battery. It has to be one of those 3 things.
  6. #6
    Well the razr m has a non removable battery. It could technically be disassembled to remove the battery, but it may impact warranty. If changing the charger doesn't work then I would suggest that you contact Verizon for a replacement if you have warranty or extended warranty
    wizzrah likes this.
  7. #7
    wizzrah's Avatar
    Posts
    Global Posts
    4,726 Global Posts
    Carrier
    Kitkat
    Quote Originally Posted by dpham00 View Post
    I didn't say anything about the warranty, but yeah it will void the warranty.
    Sent from my AT&T One X running CodefireX ROM Android Version 4.4.
  8. Thread Author  Thread Author    #8
    Well it has to be the battery..The static could be electrical charges discharging within the phone itself which could in turn screw me in the end..because if thats what was happening then all my data could be lost because i dont remember the last time i bbacked up my data..
  9. #9
    Yes, I know just wanted to make the op aware, should he decide to replace the battery.
  1. Intermittant wireless charging on ATT Note 3
    By droidnate300 in forum AT&T Samsung Galaxy Note 3
    Last Post: 05-09-2014, 05:00 PM
  2. Razr Maxx GPS No-Go
    By OhTannerbaum in forum Droid RAZR MAXX
    Last Post: 05-06-2014, 04:02 PM
  3. Stylus that does not have soft rubber tip
    By 4ringsa6 in forum Samsung Galaxy Tab 3
    Last Post: 03-24-2014, 07:34 PM
  4. New Here, not to Android
    By Gonzalo Martino in forum Introductions
    Last Post: 03-21-2014, 05:03 AM
  5. Not able to text or post pictures to facebok from home
    By tarnak in forum Verizon Samsung Galaxy S4
    Last Post: 03-20-2014, 10:55 AM
