- 10-22-2012, 11:25 AM #26
- 10-22-2012, 11:47 AM #27
Re: Battery Testimonials
1 h 45 min
Sent from my DROID RAZR HD using Android Central Forums - 10-22-2012, 11:50 AM #28
- 10-22-2012, 11:51 AM #29
- 10-22-2012, 11:58 AM #30
- 10-22-2012, 11:59 AM #31
- 10-22-2012, 12:28 PM #32
- 10-22-2012, 12:29 PM #33
- 10-22-2012, 04:05 PM #34
This thing is nuts! 10 hours off the battery. Browsed the Web for 30 minutes first thing. Went to the gym, came home, showered, then had a 45 minute conference call on the way to the office (was connected to my cars Bluetooth) and have just used it like normal today...maybe very slightly less than normal. I'm on WiFi while at home and at work. Check out the screenshot...10 hours in and I'm at 84%!!!
Sent from my Droid RAZR HD MAXX - 10-22-2012, 04:17 PM #35
I took the same action (and switched from Global to LTE/CDMA). I think that may have done the trick. I'm currently at 7 hours, 32 minuets and have only consumed 25% of my power. Not phenenomal like others have posted, but a heck of a lot better than before and better than on any other phone I have owned. To be honest though this was with using WiFi for a majority of the day. I will try tomorrow with out WiFi.
- 10-22-2012, 04:54 PM #36
You should check the other apps that sync also. For example I use scoremobile for sports and it was syncing every 2 min, I changed it to never. My k9 mail settings for sync were also more often on some accounts I don't need to sync a lot, my error when I set them up, but I noticed k9 was using a lot of battery and went back and found I hadn't changed a couple of sync intervals. I use gsam battery to keep track of battery usage. It's free.
- 10-22-2012, 05:25 PM #37
What do you think of these stats? they seem off in my mind
10h 26m 47%
voice calls 72% (4hr 9m)
screen 14% (1h 16m)
phone idle 6% (9h 10m)
android system 3% (13m)
cell standby 2% (10h 26m)
NO wifi, NO GPS, and NO bluetooth used at all. Location services disabled as well. In a 4g area 98% of my day. I'm disappointed in this battery life so far.
boasts 31 hrs of talk...i would get 8 maybe... I almost forgot to mention, on 2 separate occasions (different days) I restarted my phone and BOTH times the battery life dropped 10-11% (Friday went from 32% to 22% on restart and yesterday from 36% to 25%)
Please let me know your thoughts.
Thanks! - 10-22-2012, 05:29 PM #38Android Evangelist
HTC Desire + Samsung Galaxy SIIx + Transformer TF101 and Prime + Nexus 4 - 10-22-2012, 05:43 PM #39
I am not gonna lie, but for some reason I was expecting 40 hours easy haha. But at this rate I still can get about 30. Not bad. Better than the 8-10 I was getting on my s3.
Sent from my DROID RAZR HD using Android Central Forums - 10-22-2012, 05:55 PM #40
- 10-22-2012, 06:23 PM #41
- 10-22-2012, 06:29 PM #42
- 10-22-2012, 06:53 PM #43
I'm at 53% after 7 hours. Huge amount of usage. 58% screen usage. Is that bad?
Looking for some Android knowledge... - 10-22-2012, 07:06 PM #44
- 10-22-2012, 07:32 PM #45
- 10-22-2012, 08:02 PM #46
Still going strong...screenshots attached. My old RAZR would have died twice by now.
Sent from my Droid RAZR HD MAXX - 10-22-2012, 08:14 PM #47
- 10-22-2012, 08:18 PM #48
- 10-22-2012, 08:45 PM #49Android Evangelist
HTC Desire + Samsung Galaxy SIIx + Transformer TF101 and Prime + Nexus 4 - 10-22-2012, 09:26 PM #50
Oh I already did. The shortest sync interval I have set, for those apps where I can control it, is every 4 hours. For every app out there I have made it as long as possible. The one app I cannot control the sync interval on is Facebook. I may wind up just installing Facebook Contacts Sync and turning off Facebook sync for this reason. Speaking of which, I went through it and found a ton of sync items in FB that were turned on such as location services. So I've disabled them. So tomorrows stats ought to be interesting.
WOW! Ok so what are your settings? What apps do you have installed? What intervals are their sync settings?
Don't get me wrong, on any other phone I would have had to recharge by now so I'm happy. However I want to reach the reported life like folks like Dctobin are getting
Battery life terrible?
By bilobi in forum T-Mobile G1Replies: 20Last Post: 04-02-2013, 01:48 PM -
Improving Battery Life on Your Android Device
By ERDude in forum HTC HeroReplies: 32Last Post: 02-04-2010, 12:33 PM -
Helpful Battery Tips...
By Keith Newman in forum HTC HeroReplies: 6Last Post: 10-29-2009, 11:12 AM -
Battery Length
By wolf1989#AC in forum HTC HeroReplies: 17Last Post: 10-16-2009, 02:10 AM -
problems with camera and battery
By piper09 in forum HTC HeroReplies: 10Last Post: 10-11-2009, 05:45 PM
Reply
