Results 1 to 19 of 19
    Default This needs to be changed
    Why is there no text icon at the top?? Online album don't care..
    Amazon no..
    I want text to be there
  2. Thread Author  Thread Author    #2
    Default Re: This needs to be changed
  3. #3
    There is on mine. My list is:
    Online Album
    Bluetooth
    Picasa
    Text Messaging
    "See all"
    When I click "See all"
    about 7 more options are added to the list.
    dirkbonn
    The government can't give you anything until it first takes it from someone else.
  4. #4
    kmf1's Avatar
    Posts
    Global Posts
    122 Global Posts
    I suppose that it would be nice to have the option of rearranging the order of what choices you see first when hitting the "share" button. That way you would see the option that you most often use first, instead of having to select "see all." Maybe there is some sort of shortcut for that?
  5. #5
    I just tried and when I sent a message, the text icon was put at the top next to the icons and stayed. Did you try sending a pic thru text yet? That and dirkbonn's post tell me it might rearrange based on use or accounts on your phone?
    I am on the JB leak tho.....but still try some stuff first.
  6. #6
    Snareman's Avatar
    Posts
    Global Posts
    753 Global Posts
    ROM
    Stock
    I've noticed this as well. On my Nexus is almost seemed to arrange itself based on frequency of use, but on this phone despite sending lots of pics via gmail it continues to remain at the bottom of the list and while its not the end of the world, I do miss the convenience that I had with it on the GNex.
    Quote Originally Posted by dirkbonn View Post
    Online Album
    Bluetooth
    Picasa
    Text Messaging
    "See all"
    Right but text should be at the top..
  8. #8
    Sent from my DROID RAZR HD
    Attached Thumbnails Attached Thumbnails This needs to be changed-uploadfromtaptalk1353354894581.jpg
    Quote Originally Posted by blakke39 View Post
    How?
  10. #10
    I notice on both of their posts...Amazon isn't listed, it is on mine and yours and we have to hit see all to see text.
    Try removing or logging out of Amazon, see of the list reorders.
    I just noticed, after I sent the pic thru text, it's not on my list anymore, but the text icon is still at the top.
    Sent from my DROID RAZR HD using Android Central Forums
  11. #11
    ClintRo's Avatar
    Posts
    Global Posts
    9,926 Global Posts
    ROM
    BAMF 3.0 Sense
    I think the Quick Pic app will do this for you. I use this instead of the default gallery on all my devices.
  12. #12
    grmncrsnbr's Avatar
    Posts
    Global Posts
    3 Global Posts
    That list will reorder based on what you are using, have you tried sending some pics through texts using see all? Then go back and check the list again. The setup on the VGN is the same and mine changed based on what I had sent pics with most recently.
  13. #13
    Quote Originally Posted by homebrwd View Post
    I disagree. I've never used Picassa or online albums yet they are always at the top. Text, which I use the most frequently, is not.
    Thanked by:
    pblakk
  14. #14
    grmncrsnbr's Avatar
    Posts
    Global Posts
    3 Global Posts
    Quote Originally Posted by French View Post
    Well that sucks, maybe it changed with Jelly Bean. Initially mine wasn't in the short list now its on the top of the list.
  15. #15
    Snareman's Avatar
    Posts
    Global Posts
    753 Global Posts
    ROM
    Stock
    I think it might be a JB thing. I just installed the JB leak. when I was still on ICS they weren't ordered, but now that I have JB I noticed that gmail and text are now at the top of the list.
  16. Thread Author  Thread Author    #16
    Quote Originally Posted by Snareman View Post
    Did you root?
  17. #17
    Snareman's Avatar
    Posts
    Global Posts
    753 Global Posts
    ROM
    Stock
    No. I thought I was going to have to, but turns out you don't for the leak. It was super simple. Don't need to wipe or anything.
  18. Thread Author  Thread Author    #18
    How did you get JB with out rooting please tell I want it
  19. #19
    Snareman's Avatar
    Posts
    Global Posts
    753 Global Posts
    ROM
    Stock
    Quote Originally Posted by codysanbor View Post
  1. App access to API needs to be changed
    By ashakouri1 in forum Android Applications
    Last Post: 11-18-2010, 06:02 AM
  2. How neurotic do I need to be able killing apps?
    By Snareman in forum Verizon Fascinate
    Last Post: 11-03-2010, 11:11 AM
  3. What needs to be done to put FROYO on EVO?
    By djmannyd in forum HTC EVO 4G Rooting, ROMs, and Hacks
    Last Post: 06-20-2010, 08:28 PM
  4. I need to be able to read PDF's from E-Mails...
    By moviemogul in forum General Help and How To
    Last Post: 01-27-2010, 11:29 AM
  5. I need to be able to read PDF's from E-Mails...
    By moviemogul in forum Motorola Droid
    Last Post: 01-26-2010, 11:13 PM
