Results 1 to 5 of 5
- 11-29-2012, 10:46 AM
Thread Author #1
should I upgrade to razor hd max from razor
Hi,
Im due to upgrade now. I was wondering what you guys thought of the razor hd max? I am coming from the regular razor. The battery is lousy, aside of that the phone was nice.
I was looking a the note 2 or the dna but those dont have the sd card slot anymore and I dont want to downgrade my storage from 32 gig to 16. I store all my music on here.
Also, I don't believe quad core processing power is really worthit right now, or am I wrong? Seems that dual core is just about begining to be supported and quad ore is not even used, so is kind of useless.
suggestions?
I use email a lot and text, watch movies, listen to music and occasionally game on the device.
Thanks for any insight
Phil - 11-29-2012, 11:47 AM #2
- 11-29-2012, 11:49 AM #3
Re: should I upgrade to razor hd max from razor
There's a lot of info already in this forum to answer your questions. Have you looked?
Sent from my DROID RAZR HD using Android Central Forums - 11-29-2012, 04:47 PM #4
- 11-29-2012, 06:14 PM #5
I made the same upgrade. The post above is correct, the MAXX HD is a lot heavier, but I actually prefer the added thickness. In my opinion the regular RAZR was almost too thin. It made it difficult and uncomfortable to hold sometimes. Screen is much nicer. OS is a lot smoother on the MAXX HD as well, probably due to the different processor. The battery on this thing is ridiculous.
What should I upgrade to?
By derik123derik123 in forum General Help and How ToReplies: 7Last Post: 05-07-2011, 01:02 AM -
Thinking about upgradeing to LG Optimus S from Blackberry
By mach30 in forum LG Optimus S AccessoriesReplies: 15Last Post: 03-31-2011, 10:18 AM -
Upgrading to a 32GB SD from 16GB
By Mudvayne622 in forum Motorola Droid XReplies: 16Last Post: 03-24-2011, 12:34 AM -
should I upgrade to EVO from Hero? Any reason not to?
By Alvin in forum HTC HeroReplies: 3Last Post: 11-24-2010, 02:11 AM -
Should I upgrade to 2.1?
By Willy in forum HTC HeroReplies: 13Last Post: 06-02-2010, 08:07 PM
Reply
