Page 1 of 2 12 LastLast
Results 1 to 25 of 28
Like Tree2Likes
    blg923's Avatar
    Posts
    Global Posts
    414 Global Posts
    Default Battery Percentage in JB
    Does anyone know if we will get the battery percentage indicator in the JB update?
    Sent from my DROID RAZR MAXX HD using Tapatalk 2
  2. #2
    Default Re: Battery Percentage in JB
    Shouldn't change my mom in laws has it still with the Razr M
    Sent from my GT-N8013 using Android Central Forums
    blg923's Avatar
    Posts
    Global Posts
    414 Global Posts
    Has the percentage? Not sure what you mean by your reply.
  4. #4
    Snareman's Avatar
    Posts
    Global Posts
    749 Global Posts
    ROM
    Stock
    No. Not that I'm aware of. At least not up in the notification bar at the top. You'd have to root and get a ROM with it or just get an app like I did. I liked it better when I had a ROM on my Nexus that replaced the battery icon with a %, but no go so far on this phone.
  5. #5
    sicario666's Avatar
    AndroidSkull
    Posts
    Global Posts
    3,349 Global Posts
    ROM
    Vitreous,JellyBelly,OEM
    No need to root. Use power toggles. It will allow you to place a battery percentage in the notification bar. Also allows you to customize toggles in the notification pulldown.
    Sent from my DROID RAZR HD
    ***GET IN WHERE YOU FIT IN***
    Snitches get stitches
    Boneyard-D1,Dinc,dX,Gtab7",Tbolt,iPad1,Bionic,Xoom,iPad2,Charge,GNexus,SGS3,Razr Maxx,Nexus7...the list shall continue
    Living Dead-iPad3,GalaxyNexus,Razr MaxxHD
  6. #6
    Snareman's Avatar
    Posts
    Global Posts
    749 Global Posts
    ROM
    Stock
    Sure. You don't have to root. I was just referring to something that sort of "came with" the OS since he asked if it came with the JB update. I liked the one with my GNex rom that replaced the battery icon. Power Toggles looks like a nice option. I've been using Battery Notifier Pro.
    Attached Thumbnails Attached Thumbnails Battery Percentage in JB-screenshot_2012-12-03-11-49-49.png
  7. #7
    sicario666's Avatar
    AndroidSkull
    Posts
    Global Posts
    3,349 Global Posts
    ROM
    Oh OK I see. As for a native %age. Nowhere to be found. There's only one ROM available right now. Which is a stock ROM. No percentage there. Obviously if I'm using the toggles app
  8. #8
    Snareman's Avatar
    Posts
    Global Posts
    749 Global Posts
    ROM
    Stock
    Quote Originally Posted by sicario666 View Post
    Yea, hopefully eventually there will be some decent ROM options and choices.
    sicario666 likes this.
  9. #9
    sicario666's Avatar
    AndroidSkull
    Posts
    Global Posts
    3,349 Global Posts
    ROM
    Quote Originally Posted by Snareman View Post
    It kills me that there isn't any development for this device. Its my only single gripe. I can't complain about ANYTHING else.
  10. #10
    Who?'s Avatar
    Posts
    Global Posts
    400 Global Posts
    No, there isn't. I use GSam Battery.
  11. Thread Author  Thread Author    #11
    blg923's Avatar
    Posts
    Global Posts
    414 Global Posts
    I thought I saw JB running in the Nexus 4 stock with the percentage, maybe I was wrong...sucks, not sure why they don't add it.
  12. #12
    Who?'s Avatar
    Posts
    Global Posts
    400 Global Posts
    Again, no percentage. Battery meter is in fact worse looking than in ICS.
  13. #13
    The ring widget isn't available? That has the battery indicator
    Sent from my DROID RAZR HD using Android Central Forums
  14. #14
    McIrish's Avatar
    Posts
    Global Posts
    81 Global Posts
    That widget is called Circles and its still in JB. Works as it always did except you can't select desk clock mode from in it anymore. But, there is a seperate clock app for that now.
  15. #15
    Potent68's Avatar
    Posts
    Global Posts
    18 Global Posts
    Our circle apps on our Razr Maxx HD's have NOT changed since updating to Jelly Bean this evening. They still show the percentage and the colored circle around it in the far right circle like they always have. I hope that helps.
  16. #16
    Quote Originally Posted by blg923 View Post
    Sent from myRT's Maxx HD
    Yep! Lovin' it. I never used the circles before..used nova launcher and a battery app. Circles was updated and more accurate so I've been using this the past week and liking it so far.
    Thanked by:
    Shuckster likes this.
  17. #17
    I would love to use Circles but I noticed a 20% extra battery drain. Is there any hidden way to change the weather update schedule to prevent this?
  18. #18
    Even with the circles widget in JB the battery percent indicator is only available on the homescreen that the circles is on. I use the app "Battery Notifier Pro" which puts the battery percent indicator in the notification bar at the top. This way I can see the battery percentage on any screen I'm viewing at the time. Battery notifier pro also monitors phone temperature, battery voltage out to 3 decimal points. Also have the battery percentage in various colors of your choosing, also you can have sound alerts.
    I'm now just patiently waiting for the release of my next smartphone (after my current Maxx HD) sometime in the Summer of 2014.
    dirkbonn
    The government can't give you anything until it first takes it from someone else.
  19. #19
    Power toggle question. How did you get two rows of controls in your notifications area?
    Sent using the Amazing RAZR MaxxHD
    "When you turn your Android on, does it return the favor?"
  20. #20
    SET001's Avatar
    Posts
    Global Posts
    39 Global Posts
    Choose Settings>Display>Display battery percentage. Don't know in 4.2 But this works on mine in 4.1.1
  21. Thread Author  Thread Author    #21
    blg923's Avatar
    Posts
    Global Posts
    414 Global Posts
    Quote Originally Posted by SET001 View Post
    This is not an option on this phone with 4.1.1...are you using a Samsung device, I think they have the option.
  22. #22
    Snareman's Avatar
    Posts
    Global Posts
    749 Global Posts
    ROM
    Stock
    Yea. Not an option for me either on 4.1.1
  23. #23
    SET001's Avatar
    Posts
    Global Posts
    39 Global Posts
    Yes using Samsung S3. Sorry that it doesn't work for you. Great feature without the need for another widget.
  24. Thread Author  Thread Author    #24
    blg923's Avatar
    Posts
    Global Posts
    414 Global Posts
    I agree, it is def a touchwiz feature. This phone is 99% vanilla so I really didn't expect us to get the option. It is the only feature missing for me that would make this phone the best ever...yes, something this small.
  25. #25
    any chance you could share this wallpaper
  1. Numerical battery percentage in the status bar, PLEASE
    By android010 in forum Android 4.1 / 4.2 Jelly Bean
    Last Post: 04-25-2013, 10:05 AM
  2. Numerical Battery Percentage in Status bar?
    By AndroidBlizzard in forum HTC One X
    Last Post: 07-11-2012, 06:41 AM
  3. Battery percentage in increments of 10 percent?
    By edgewise225 in forum Sprint Photon
    Last Post: 08-01-2011, 02:03 PM
  4. Battery percentage in status bar cyanogenmod?
    By callofduty4 in forum Incredible Rooting, ROMs, and Hacks
    Last Post: 07-11-2011, 07:33 AM
  5. How to display battery percentage in icon?
    By rjack22 in forum Verizon Fascinate
    Last Post: 05-11-2011, 01:57 PM
