- 12-29-2012, 02:56 PM
Thread Author #1
Will it fit?
I have wanted an Otterbox Defender in camo and blaze orange for a long time, almost enough to go iPhone. Now they offer it for the HD but said no plans for the MAXX HD. Since the HD is .33 thick and the MAXX HD is .37 thick, what are the chances it would fit?
Sent from my DROID RAZR MAXX HD using Tapatalk 2 - 12-29-2012, 08:06 PM
Thread Author #2
Re: Will it fit?
Someone has to have a guess...can't believe someone doesn't have access to one of these cases. I guess I might have to buy one and if it doesn't fit, return it.
Sent from my DROID RAZR MAXX HD using Tapatalk 2 - 12-30-2012, 03:46 PM #3
- 12-30-2012, 04:51 PM #4
Re: Will it fit?
While I would normally agree with what Tony Wayman said, a friend of mine has the defender case on a Samsung Galaxy S3. He has a stick-on screen protector AND the built in screen protection from the defender and I will say that it does fit. It actually had a little play as well, but that may be caused by the stick-on. I will also say that with the way they cut out the "eat hole" of the built in protector of the defender for both the SIII, and the RAZR MAXX HD, I will not be going with otterbox for the first time in 3 phones. I think the design actually CAUSES damage instead of protecting against it.
Sent from my Droid RAZR MAXX HD using Android Central forums app - 12-30-2012, 04:57 PM #5
Re: Will it fit?
Uhhh, after rereading the OP, I realized my post might seem like a random ramble. What I was going for was the following translation:
I think otterbox has slipped in their tolerances so it would most likely work.
Sent from my Droid RAZR MAXX HD using Android Central forums app - 12-30-2012, 08:21 PM
Thread Author #6
Re: Will it fit?
Thanks, I'm going to see if I can find the case in a local best buy or brick and mortar (doubtful). If not, I'll bite the bullet and order it directly and hope it fits.
Sent from my DROID RAZR MAXX HD using Tapatalk 2 - 01-07-2013, 03:49 PM #7
- 01-08-2013, 11:12 AM
Thread Author #8
Re: Will it fit?
I still need to check with local stores to see if they have just a plain defender and if they don't, I'll order. I'll update when I do, hopefully within the month.
Sent from my DROID RAZR MAXX HD using Tapatalk 2 - 01-08-2013, 02:12 PM #9
- 01-08-2013, 08:34 PM #10
Re: Will it fit?
Come on, no "That's what she asked" response?
- 01-09-2013, 07:42 PM
Thread Author #11
Re: Will it fit?
You are speaking to a big The Office fan and an even bigger That's what she said fan hahah
Sent from my DROID RAZR MAXX HD using Tapatalk 2 - 01-24-2013, 02:41 PM
Thread Author #12
Re: Will it fit?
Bit the bullet and ordered the Defender in camo for the HD last night...will let everyone know if it fits when it arrives. Per the specs, the MAXX HD is only 1/25" larger in thickness and I have trouble believing Otterbox uses that small of a build tolerance. Crossing my fingers!
Sent from my DROID RAZR MAXX HD using Tapatalk 2 - 01-25-2013, 08:03 PM #13
Re: Will it fit?
May have to remove some padding or mood it some. I hope not.
Sent from my Transformer Prime TF201 using Tapatalk HD - 01-26-2013, 02:54 PM
Thread Author #14
Re: Will it fit?
I'm hoping its just a really tight fit. The thing I'm fearing the most is an incomplete wrap by the soft shell. Should be here Monday.
Sent from my DROID RAZR MAXX HD using Tapatalk 2 - 01-28-2013, 11:56 AM
Thread Author #15
Re: Will it fit?
Well, it's not a PERFECT fit but it fits. I think there was one clip on the 2 plastic pieces that I couldn't get snapped but after wrapping the rubber piece around it, you'd never know. I pulled the foam piece on the lower hard plastic part off initially because I thought that's what the issue was but it didn't make a difference.
- 01-28-2013, 10:47 PM #16
Re: Will it fit?
Why'd you change your username?
- 01-28-2013, 11:17 PM
Thread Author #17
Re: Will it fit?
That Passport crap has a mind of its own.
Anyways, back to the topic...I played with the case a bit more this evening and was able to get all clips to snap. Success.
Sent from my DROID RAZR MAXX HD using Tapatalk 2 - 01-31-2013, 11:20 PM #18
- 02-02-2013, 10:32 AM
Thread Author #19
Re: Will it fit?
Did you order the Defender in camo? That's the only reason I ordered it for the regular HD. I will note, it takes some work to get the clips in and I do notice it needs a tightening every once in a while if you use the volume rocker often but IMO, its worth it.
Sent from my DROID RAZR MAXX HD using Tapatalk 2 - 02-03-2013, 07:04 AM #20
- 02-09-2013, 06:01 AM #21
- 02-09-2013, 08:08 PM
Thread Author #22
Re: Will it fit?
It seems like over time, the fit gets better. As I mentioned before, the ONLY thing I notice from time to time is that you have to squeeze it tighter on the right side as the volume rocker separates the two pieces slightly. Regardless, I'm still very happy to have this case finally!
Sent from my DROID RAZR MAXX HD using Tapatalk 2 - 02-18-2013, 08:28 AM #23
Micro USB 3.0 - will it fit?
By Stevies in forum HTC EVO 3DReplies: 3Last Post: 08-28-2011, 02:30 PM -
Samsung Intercept... will it fit my needs?
By islei in forum General Help and How ToReplies: 1Last Post: 06-20-2011, 08:55 PM -
Will it still fit in the desk cradle with ZAGG shielf on back?
By Snareman in forum Fascinate AccessoriesReplies: 7Last Post: 11-03-2010, 03:14 PM -
What all will android 2.1 include and when will it be released?
By xrawringxdinox in forum Samsung MomentReplies: 0Last Post: 03-01-2010, 10:38 PM -
When N1 goes to VZ will it be sold in the store?
By CSI Guy in forum Google / HTC Nexus OneReplies: 11Last Post: 01-13-2010, 05:25 PM
Reply
