1. Tommy Clarkson's Avatar
    So I took the plunge...
    I've only owned my droid maxx HD for a few days now.. but noticed that the battery life isn't matching up to other stats I've seen online by other users. I know people have mixed feelings on this ... but I did a full battery discharge until my phone turned off by itself. Then from there with out turning the phone on, I let it charge while off too a full 100% again. I tell you what, this process brought my battery to life. I'm at 94% right now and have been using my device for over 3 hours. As to yesterday at this time, I was at around 75% rather than 94%. As I said before, I know people have different thoughts on this, and say its not recommended or needed to let your battery fully discharge, but this worked miracles for me. Not that I recommend doing this often by no means, that was probably the first and last time I'd do it.
    I even used this app to help discharge it faster...
    https://play.google.com/store/apps/d...fast+discharge
    Anyways .. just my thoughts on this process ...
    Attached Thumbnails Battery Improvement ..   Drain & then charge.-screenshot_2013-02-19-07-56-12.png
    02-19-2013 07:02 AM
  2. whoover's Avatar
    The battery life improves noticeably after the first three or four charge cycles, even if it's only discharged partially. I suspect you would have gotten to the same place in a few more days without a complete discharge.
    I've had mine since October and forgot how big an effect it is until we just got one for my wife a few weeks ago. She complained the battery life wasn't like mine for a few days but now it's even better than mine.
    02-19-2013 05:36 PM
  3. Dreamliner330's Avatar
    Also keep in mind 'standby' time is virtually meaningless. The real important things are screen-on time and Talk Time. I was able to get 26+ hours with 5 hours of screen-on time and 4 hours of talk time...all without hitting the low battery indicator!
    02-19-2013 07:05 PM
  4. blg923's Avatar
    Also, you should never let a Li-Ion battery discharge completely.
    Sent from my DROID RAZR MAXX HD using Tapatalk 2
    02-21-2013 06:44 PM
  1. Battery issues; drains 40% overnight.
    By ashakouri1 in forum HTC EVO 4G
    Last Post: 02-05-2011, 07:20 AM
  2. Replacement/Spare Battery from China won't charge!!
    By stedyone in forum Verizon Fascinate
    Last Post: 11-22-2010, 04:32 PM
  3. Replies: 20
    Last Post: 09-15-2010, 05:37 PM
  4. Battery improvements in Android 2.2???
    By callofduty4 in forum Verizon Droid Incredible
    Last Post: 07-28-2010, 01:15 PM
  5. Major battery improvement because of update?
    By Kedar in forum HTC EVO 4G
    Last Post: 07-02-2010, 01:14 PM
