Re: LED notification light
LightFlow is pretty much the best one.
What I do is disable the LED in each individual App itself then enable it only in LightFlow.
The fact that both are trying to blink the LED might be causing the inconsistencies you're experiencing.
Personally I have no problems with it.
Me too.
I had problems when I first got my phone though too. Did a factory reset, and added my accounts myself, and it seemed to work fine then.
You can also try Notification Light Widget in the Playstore. Made by Motorola to address the problem some users are having.
Update with what? Phone or app
Sent from my DROID RAZR HD using Android Central Forums
How do you disable the LED in each App? Like in Email, or SMS, or do mean add on apps? My Lightflow is working on my Motorola Electrify M, but if I get an SMS (blue) and an email (orange), for example, both are set to "fast" but I get something like 9 blue blinks, alternating with 9 or so orange blinks. How do I get them to flash sequentially? Thanks.
newtda, try this: [Only registered and activated users can see links. Click Here To Register...]
The light not working was a common issue, so Motorola put out a widget to turn on and off the notification light a while back.
Any thoughts on why the lights are not alternating, but I'm getting several of one color, then the other?
I already have the widget, that doesn't help much. I am going to call Verizon and see what they say.
Quote:
I just bought the droid raza Maxx HD on saturday, I love it so far. How do i turn on the LED notification light? I tried to google it but didn't find anything. I read that people use Light Flow Lite. I dl it and that only works half the time. let me know what I am doing wrong or if there is a better app for the notification light.
Saw this on Google Play
From the reviews:
mekayla snyder - February 27, 2013 - Motorola Droid RAZR with version 3.6
Loveeeee it
This is the only personalized LED app u could find that works for my phone (RAZR Maxx HD) all the time with no glitches. I absolutely love it!
I don't have this app, but I was looking into getting a notification app and this jumped out at me.
Thank you for (partly) restoring my sanity! I love Lightflow, but the dang notification light wouldn't turn off, so had to keep manually resetting it. Finally dropped the $2 and bought the full version so that I could get the VM notification, too (how dumb is that, to leave that out?), hoping that would fix it, but no. Kept playing with settings to no avail. Once I downloaded that notification app from VZW, all is well.
Light flow works perfectly if settings are correct. Email the dev if you have a problem. He is very helpful. I don't know if u noticed but there is also a lightflow widget that shuts off notifications with one push.
Sent from my DROID RAZR HD using Tapatalk 2
