Results 1 to 9 of 9
    Default Why does "Android OS" have a massive drain on my battery every once in a while.
    I have a Razr Maxx HD, love the phone and the battery life, but every once in a while it will have Android OS suck a lot of battery and I wont be able to get through the day with it. Is there something that I can do to stop this?
    Attached Thumbnails Attached Thumbnails Why does "Android OS" have a massive drain on my battery every once in a while.-2013-12-23-10.02.11.png   Why does "Android OS" have a massive drain on my battery every once in a while.-2013-12-23-10.02.19.png
  2. #2
    Golfdriver97's Avatar
    Posts
    Global Posts
    13,895 Global Posts
    ROM
    Stock Moto X
    Default Re: Why does "Android OS" have a massive drain on my battery every once in a while.
    Based on the screenshots, I am going to guess at 2 things: 1. Your device is idle a lot. That is why the OS is so high. The OS is only taking up 23% of the 21% drain as shown in your pictures. 2. You cell signal look very weak. Your device is probably spending more energy maintaining that weak signal than the OS is draining your battery.
    Test to see if I am correct: Put your phone in Airplane mode for a little while. If you make it longer throughout the day, then it is the cell radios that's killing your battery.
    Devices: Current: Nexus 5, Moto X, Galaxy Tab 2 (7.0); Retired: Galaxy S2 (Epic 4G Touch); Traded: Galaxy S3
    When I let go of what I am, I become what I might be - Lao Tzu 'If we could change ourselves, the tendencies in the world would also change.' - Mahatma Gandhi
    Community Guidelines and also here
    In my area I am in and out of coverage all the time (this was the reason I got the Razr Maxx hd), i understand that and can live with it. It's just that once every week or two i have the Android OS go crazy and suck the battery down on me. I would normally be in the low 90% to high 80% range at this time of the morning.
  4. #4
    Posts
    Global Posts
    13,895 Global Posts
    ROM
    Stock Moto X
    You can try clearing cache in recovery, but I don't know how on your device.
    From a Sprint Moto X using AC Forums app
  5. #5
    joe_fresh's Avatar
    Posts
    Global Posts
    1,467 Global Posts
    ROM
    HTC One stock
    Quote Originally Posted by Golfdriver97 View Post
    1. With the phone powered off, press the VOL UP + VOL DOWN KEY together + POWER KEY .
    2. The device will display different BOOT OPTIONS
    3. Use the VOL DOWN Key to SCROLL to Recovery and VOL UP Key to SELECT
    Tip: If the device reboots, you may have waited to long to make a selection, you will need to begin the process again.
    4. The device will display the Motorola logo and then the Android in distress ( logo with Exclamation mark)
    5. Press and hold the VOL DOWN key, then tap and release the VOL UP key.
    Tip: You can try this step, holding the phone in landscape. If you are stuck on step 5, try a force reboot by pressing the power Key and Vol Down key, and start the process again.
    6. The device will display additional menu options (Text will appear in BLUE)
    7. Use the VOL DOWN Key to scroll to wipe cache partition and the POWER Key to SELECT this option.
    8. The device will then perform the partition wipe
    9. Once the Formatting is complete, press the POWER key to confirm a REBOOT
    11. The device will reboot and start the normal power up sequence .
    Blackberry Curve 8330 - Blackberry Storm 2 9550 - iPod Touch 4th gen - Apple Iphone 4 - Motorola Droid RAZR MAXX HD Motorola RAZR HD (wife) - HTC One
    Thanked by 2:
  6. #6
    Posts
    Global Posts
    13,895 Global Posts
    ROM
    Stock Moto X
    Cool. Thanks for the post!
  7. #7
    joe_fresh's Avatar
    Posts
    Global Posts
    1,467 Global Posts
    ROM
    HTC One stock
    Actually did this today. Yesterday my battery was being destroyed seems to be good today.
    Motorola DROID RAZR MAXX HD via Android Central App
  8. #8
    Posts
    Global Posts
    13,895 Global Posts
    ROM
    Stock Moto X
    Quote Originally Posted by joe_fresh View Post
    Hope that helps. It should. Typically after every update, clearing cache should be done.
  9. #9
    joe_fresh's Avatar
    Posts
    Global Posts
    1,467 Global Posts
    ROM
    HTC One stock
    I do this once a week. We haven't had any updates lately. I know kit kat is coming but it could be another month
  1. New Galaxy Gear Firmware showing up on 12-23 (post MK7)
    By waynew73 in forum Samsung Galaxy Gear
    Last Post: 12-24-2013, 10:03 AM
  2. Change in Battery Behavior - Due to Belt Case?
    By Unobtanium in forum Motorola Droid MAXX
    Last Post: 12-23-2013, 07:22 PM
  3. Getting text massages in 2 places?
    By Flipadelphia26 in forum Samsung Galaxy Note 3
    Last Post: 12-23-2013, 04:22 PM
  4. Can't put files onto my Nexus :(
    By PikadudeN64 in forum Android 4.1 / 4.2 / 4.3 Jelly Bean
    Last Post: 12-23-2013, 09:40 AM
  5. Cubot C9W android phone
    By IONx64 in forum General Help and How To
    Last Post: 12-23-2013, 08:38 AM
B
