Ever since my phone updated to Kit Kat last week it's been doing a couple of weird things. Overall it's working much better (better battery life for sure!) but these things are an annoyance. I already made a post about the first issue (not staying in vibrate mode), here's the one for my other issue.
Since the upgrade my phone is talking to me when it rings. It will ring, and then speak the phone number/name of the caller, and repeat. I thought this must be something in accessibility (even though I hadn't changed any settings, started doing this on it's own after the upgrade) but I can't find the option for this anywhere. I know in the Motorola SmartActions app that's one of the features you can turn on, and I have that enabled when the Drive mode action is enabled, but it does this even when the phone is not in Drive mode, and even when there aren't any SmartActions active at all. I don't believe it's SmartActions that's causing this, because that feature announces text messages as well and this is only happening for phone calls not texts. I cannot find any information on how to turn this off. I also use the app "LightFlow" to manage notifications on the phone, but do not have a notification set for incoming calls (though maybe if I set the ringtone to none in the phone's settings and enable this notification in LightFlow it won't happen anymore, I'll have to try that if no one knows how to fix this)
I'm thinking of doing a factory reset on the phone but thought I'd see if anyone else had noticed similar behaviors or knew how to turn this feature off.
