Results 1 to 3 of 3
    cmyoch's Avatar
    Posts
    Global Posts
    29 Global Posts
    Default Motorola helped me with a volume level issue since Kit Kat
    I just wanted to share this to help out anyone else with the same issue. Since the Kit Kat update the volume levels for phone calls on my phone using the handset or speaker were lower than normal. Increasing the volume using the side toggle or maximizing the volume levels in Settings did not help. Tech support at Motorola had me power down the phone, reboot in Recovery mode, and wipe the cache partition. This solved this particular issue. It may solve other issues as well. It may be worth a try.
    The guy at Motorola told me that there will be an update rolling out soon but what issues this solves and if the Maxx HD is included is unknown because I didn't ask.
  2. #2
    Default Re: Motorola helped me with a volume level issue since Kit Kat
    With all the little issues I've been reading about and a couple small things on my phone, I hope the update will include the Razr Maxx HD to fix some of these issues.
  3. #3
    kmf1's Avatar
    Posts
    Global Posts
    531 Global Posts
    Wiping the cache partition is good for a lot of issues, and the well-being of the phone in general. I do so once every couple of weeks. Thanks for sharing.
    Sent from my Droid Razr Maxx HD using Tapatalk.
  1. Towel Root and help request
    By philosopherisdog in forum LG G2 Rooting, ROMs, & Hacks
    Last Post: 10-12-2014, 04:24 PM
  2. can't connect to the internet with my htc one x
    By peterc davis in forum Ask a Question
    Last Post: 06-19-2014, 09:46 PM
  3. S3 firmware update problem !!! Help !!!
    By Vikash Srirangam in forum Samsung Galaxy S3 I9300
    Last Post: 06-19-2014, 03:27 PM
  4. I hate kit kat....
    By Jared Greene in forum Ask a Question
    Last Post: 06-19-2014, 09:52 AM
  5. Just call me butter fingers!
    By Ginger Lynn in forum Ask a Question
    Last Post: 06-19-2014, 08:54 AM
