1. mobrules's Avatar
    I use the smart actions app/settings. It is set to disconnect all connections when my screen goes dark. Makes the battery last 3-4 days usually. I tried switching to ART and using the exact same settings the battery only lasted 24 hours on average. I didn't change any other settings. Using the application Better Battery Stats really didn't show anything that stood out. Has anyone had results like this?
    Sent from my Nexus 10 using AC Forums mobile app
    07-15-2014 08:00 AM
  2. Golfdriver97's Avatar
    Better Battery stats might not be coded for ART. That might be the reason you aren't seeing any difference.
    07-15-2014 08:31 AM
  3. mobrules's Avatar
    Very true. I was more shocked by the difference with the performance of the battery.
    07-15-2014 09:05 AM
  1. Replies: 1
    Last Post: 02-27-2015, 01:32 AM
  2. Pandora Issues
    By wezra in forum Samsung Gear Live
    Last Post: 07-16-2014, 10:31 AM
  3. Razr maxx hard reset pros and cons
    Last Post: 07-15-2014, 12:53 PM
  4. Using ART first day
    By chaingangritesh in forum Google Nexus 5
    Last Post: 07-15-2014, 08:42 AM
  5. S Planner Dots and lines no brief description
    By Unregistered in forum Ask a Question
    Last Post: 07-15-2014, 05:54 AM
