1. godbout.t's Avatar
    So i got the maxx and love it to death but was wondering if its correct that the battery only reports in 10% intervals. for instance took it off the charger at 6am its not 9am and its down to 90% but i dont think its actually 90....any thoughs
    02-02-2012 07:45 AM
  2. Joe378's Avatar
    I believe 90% means the battery level can be between 85% to 94%. Above 94%, it would show 100%. Below 85%, it would show 80%. I believe it rounds. I can't find a good 1% widget that works as I was looking in the market last night when I bought this phone.
    02-02-2012 08:09 AM
  3. fatboy97's Avatar
    Battery Indicator is a good widget that will report in 1% increments... but it does cost you a little money. Battery Circle is another good one that is also free that will report 1%.
    02-02-2012 08:13 AM
  4. godbout.t's Avatar
    awsome circle works great! thanks finally 1% intervals
    02-02-2012 08:16 AM
  5. godbout.t's Avatar
    Thanks btw
    02-02-2012 08:16 AM
  6. Joe378's Avatar
    I installed it on by Razr MAXX and is only showing by 10% increments. Is there a difference between Battery Indicator and Battery Indicator Pro which cost $1.99?
    02-02-2012 08:25 AM
  7. fatboy97's Avatar
    Sorry, I'm using Battery Indicator Pro since I wanted to contribute to the programmer that made it... in the settings of Pro there is a setting under Other Settings to check for a "One-percent hack" which works on Motorola phones... hope it's on the free version.
    02-02-2012 08:52 AM
  8. anthony2558's Avatar
    You have to go into menu< settings and select 1% hack.
    Sent from my DROID RAZR using Tapatalk
    Joe378 likes this.
    02-02-2012 08:55 AM
  9. Joe378's Avatar
    It worked...thanks!
    02-02-2012 09:00 AM
  10. cdf3's Avatar
    I installed Circle Battery Widget.
    So far it's working OK.
    I like it because I was looking for one that would display as a widget on one of my home screens, rather than taking up space in my notification bar.
    04-06-2012 07:36 AM
