Results 1 to 8 of 8
    Preduck's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default battery doesn't fully charge
    Whenever I don't use the Motorola charger that came with my razr maxx, my battery doesn't seem to fully charge. I'll leave it over night and I'll wake up to 40% although it was at 30% to start with. I threw it on my old blackberry car charger tonight and it said charging, but never budged past 5%. Is there something wrong with my non motorola chargers?
  2. #2
    anthony2558's Avatar
    Posts
    Global Posts
    1,575 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Stock
    Default
    I don't have a problem using other chargers. You may have something wrong with your phone.
    Tapatalk via Razr Maxx
  3. #3
    fatboy97's Avatar
    Posts
    Global Posts
    13,486 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: battery doesn't fully charge
    Or there IS something wrong with your old BB car charger. My BB car charger works just fine with my Maxx... so does my extra USB cord I purchased a LONG time ago sitting at work for years.
  4. #4
    socarwolverine's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I use the charger from the old LG EnV Touch, and it fully charges it every time.
  5. #5
    cbreze's Avatar
    Posts
    Global Posts
    3,318 Global Posts
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    my non Motorola charger works fine also. try some different chargers.
    Preduck's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    might be the chargers. it tried it on another razr and it did the same thing.
  7. #7
    Paul627g's Avatar
    Posts
    Global Posts
    17,762 Global Posts
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Gotta be the chargers then... Only takes a slight break in the wire or one of the little pins/connection points on the tip to ruin the connection.
  8. Thread Author  Thread Author    #8
    Preduck's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Both charge my htc incredible just fine....maybe they don't put out enough juice?
