Results 1 to 8 of 8
    Default battery doesn't fully charge
    Whenever I don't use the Motorola charger that came with my razr maxx, my battery doesn't seem to fully charge. I'll leave it over night and I'll wake up to 40% although it was at 30% to start with. I threw it on my old blackberry car charger tonight and it said charging, but never budged past 5%. Is there something wrong with my non motorola chargers?
  2. #2
    anthony2558's Avatar
    Posts
    Global Posts
    934 Global Posts
    ROM
    Stock
    Default
    I don't have a problem using other chargers. You may have something wrong with your phone.
    Tapatalk via Razr Maxx
  3. #3
    Default Re: battery doesn't fully charge
    Or there IS something wrong with your old BB car charger. My BB car charger works just fine with my Maxx... so does my extra USB cord I purchased a LONG time ago sitting at work for years.
    Droid Razr Maxx
    HTC Thunderbolt (Retired)
    HTC myTouch 4G (Retired)
    Blackberry's 8900 to Bold (Retired)
    Flames Wallpaper
    Jerry: "Love, Peace, and Chicken Grease!!!"
  4. #4
    I use the charger from the old LG EnV Touch, and it fully charges it every time.
  5. #5
    my non Motorola charger works fine also. try some different chargers.
    might be the chargers. it tried it on another razr and it did the same thing.
  7. #7
    Paul627g's Avatar
    Posts
    Global Posts
    13,749 Global Posts
    ROM
    Milestone 1/Lean Kernel
    Gotta be the chargers then... Only takes a slight break in the wire or one of the little pins/connection points on the tip to ruin the connection.
  8. Thread Author  Thread Author    #8
    Both charge my htc incredible just fine....maybe they don't put out enough juice?
