Results 1 to 6 of 6
    Default Battery Test
    So I had to make a trip today that was roughly 2 1/2 hours from home. When I travel I always have navigation going and am also usually streaming pandora. When I left my house my battery widget said 90% (it only shows in 10% increments). I decided to make tbe trip without use of my car charger just to see how the battery held up. During the trip I was pretty well split 50/50 between 3g and 4g service and when I arrived at my destination my battery widget showed 70% remaining. That's pretty dang good if you ask me. My old Tbolt would've probably need charged half way through the trip lol.
  2. #2
    Default Re: Battery Test
    Pretty good... if you'd like to see a more accurate battery life than the 10% battery life ticker you might try Battery Indicator, which has a paid version called Battery Indicator Pro... my current favorite... they give 1% changes. And I think there are a couple other battery widget's that will work with Motorola device's.
    Samsung Galaxy S4
    Droid Razr Maxx, HTC Thunderbolt, HTC myTouch 4G (Retired)
    Blackberry's 8900 to Bold (Retired)
    Flames Wallpaper
    Jerry: "Love, Peace, and Chicken Grease!!!"
  3. #3
    For 1% battery level increments, I use Circle Battery. I think it's free.
  4. #4
    Yeah, Circle Battery is a nice app. Simple, elegant, small app size, customizable, free!
  5. #5
    Quote Originally Posted by Just a Guy View Post
    Battery Circle will give you a 1% increment battery stat on your notification bar.
    Circle Battery Widget will give you a 1% battery increment widget on your home screen.
    Droid Razr Maxx & Nexus 7 (16 GB)
    If I helped you or you like what I said, hit "Thanks" or "Like".
  6. #6
    Default
    +1 for circle battery
