Results 1 to 6 of 6
    Ryp11's Avatar
    Posts
    Global Posts
    81 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default battery not charging
    is anybody else having issues with the maxx not charging? I've left it plugged in over night as it was at 40% and it showed that it was pluged in and charging but in the morning it's still at 40%. I'm using the same cord that I use to charge my dinc and that works fine. Thanks
  2. Thread Author  Thread Author    #2
    Ryp11's Avatar
    Posts
    Global Posts
    81 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: battery not charging
    I think I found it, I had a smart action set to not charge overnight. The phone is charging now so that made me think of the smart action or "dumb action" in my case. I think I need to go back to bed.
  3. #3
    fatboy97's Avatar
    Posts
    Global Posts
    13,486 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Good to see you fixed your problem.
  4. #4
    bluwtr49's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I wonder why that option is even available.
  5. #5
    MA2GA28's Avatar
    Deluxe Member
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by bluwtr49 View Post
    Probably for when the phone is connected to an external source (computer, TV, etc.) in case you don't want your phone charged while it is hooked up. That's all I can think of off the top of my head.
  6. #6
    Khambre's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    i charged my android using just the usb cable and it gets up to 59 percent and stays there then when i use the wall charger and keep it charged all night when i wake up in the morning my phone is dead with no charge on it at all , what can be the cause of that ? i tried turning my phone off over night to see if it would work but nothing is working PLEASE HELP ....
