Results 1 to 6 of 6
- 05-08-2012, 12:58 PM
Thread Author #1
Help with windshield mount
So this is gonna sound weird, but I do a little storm chasing in my free time, and i am looking for windshield mount for my maxx so I can use radar/GPS while it is mounted. But I also want to be able to use the camcorder while I am driving, does anyone know of a mount that allows me to do this?
- 05-08-2012, 02:20 PM #2
- 05-08-2012, 03:35 PM
Thread Author #3
Well that doesn't really let me use the camcorder while its mounted to film what's in front of me.
- 05-08-2012, 06:42 PM #4
Re: Help with windshield mount
I would think the only option would be to find a universal windshield mount... Since you want to record while driving you would want to find one that does not have the long extended arm...that would shake too much. Too bad the Motorola windshield mount blocks the camera...it has the short arm and would be perfect. I wonder if you could get a dremmel drill and modify the moto mount so the camera would be clear.
- 05-08-2012, 07:13 PM
Thread Author #5
That's a good idea. I can probably just cut a hole out. Ill look into it
- 05-10-2012, 10:52 PM #6
Reply
