Results 1 to 8 of 8
    Default My phone is possessed. Help!
    My phone it's just started speaking for no reason when I text! Just out the blue. Can't figure out why!! Please help!
    Sent from my DROID RAZR using Android Central Forums
  2. #2
    Default Re: My phone is possessed. Help!
    Did you load any new apps???
    Droid Razr Maxx
    HTC Thunderbolt (Retired)
    HTC myTouch 4G (Retired)
    Blackberry's 8900 to Bold (Retired)
    Flames Wallpaper
    Jerry: "Love, Peace, and Chicken Grease!!!"
  3. #3
    Speaking as in reading what you type? Or is it saying something else?
    Droid Razr Maxx & Nexus 7 (16 GB)
    If I helped you or you like what I said, hit "Thanks" or "Like".
  4. #4
    PanchoPlanet's Avatar
    Posts
    ROM
    Calkulins E4GT.ROM.v3.0
    Default
    What language?
    Pp.
    Sent from my SPH-D710 using Android Central Forums
    Thanked by:
  5. #5
    Default
    Androids are not point and shoot. They are more complicated and as such you can easily set something wrong by 'playing with your settings or giving permissions to an application to modify your settings. Start by checking 'Accessibility ' in your settings. There's a thing called voice read outs. It's for handicapped persons mostly. Make sure it is not on. If it is, you or some app turned it on.:-) And always check all the permissions listed for any app you download.
    Sent using Droid Razr Maxx
    "When you turn your Android on, does it return the favor?"
    Default
    Thanks for all the info I found it! It was "Thumbs keyboard" it just started doing it out the blue! thanks guys
  7. #7
    Glad you got it figured out.
  8. #8
    Default
    Ooo crazy!
