Results 1 to 7 of 7
- 05-20-2012, 06:57 AM
Thread Author #1
Help turning LED off, ALL the way off? thanks!
I'm interested in doing this without rooting. But with my old web o s phone I was able to find a patch to allow me to turn the front led of all the way off, for ever for good. Is there a way to do this in android without rooting? I found a few that would allow to the configuration but none of them will turn it all the way off. The most I would want would be a notification for battery charger. I am on a Razr Maxx.
- 05-20-2012, 07:52 AM #2
Re: Help turning LED off, ALL the way off? thanks!
Not that I'm aware of... possibly when it gets updated to ICS you'll have the option in the settings... but the only other thing I can think of at the moment is LED Light Flow which has a "sleeper setting" (obviously only temporarily).
- 05-20-2012, 08:18 PM
Thread Author #3
Thank you so much. Yes I did try that once and eventually it was suggested it would do what I needed if I purchased the full version. But we finally reached in agreement that it would not turn the led all the way off and suggested the piece of tape which I'm not going to do. Ha ha ha ha
- 05-21-2012, 08:16 AM #4
I could be mistaken, but most notification settings include the LED, don't they? I know my LED ONLY blinks when I have a text, and I know exactly where to go to turn it off for that. I'll have to go back to other push notification settings to see if I actively switched LED off, but I think it's possible.
- 05-21-2012, 08:12 PM
Thread Author #5
Admittedly I am new so I don't know what white / blue / green / red actually mean. I even set that "sleeper" mode to 24 hours, it never worked 100%
Sent from my DROID RAZR MAXX using Android Central Forums - 05-21-2012, 08:20 PM #6
- 05-22-2012, 11:03 AM #7
Take a black or other color permanent magic marker to the LED, let it dry hit it again until your liking.
It will dim it out and can be taken off with a dab of alcohol
So you won't ruin the phone
There is also a few APPs mostly for "Rooted", there are other APPs you can try out if not Rooted, just check the play store, sorry I don't have any names of the APPs.
Hope that helps
•» Tip: Never rush to download any APP "Updates", read the feedback for a few days so that you can see if other people are having issues with it and/or changes to permissions or other you may not want! Always use a Back Up APP!
•» Free DropBox! Back up to & Sync your Phone to your Computer Free! Always have your stuff when you need it with @ Dropbox . 2GB Plus account is Free! Plus earn up to 500 Mb's for each referral! Up to 32GB Free! http://db.tt/szmjeyX
Reply
