Page 1 of 2 12 LastLast
Results 1 to 25 of 28
Like Tree3Likes
    Default On second Max......battery is much better
    Verizon gave me a new Maxx since my first one had a battery that barely lasted a day with minimal use. So far the new Maxx is rocking the battery. It's like night and day. First charge lasted almost 18 hours. I'm on second full day and it's been almost 12 hours and it's at 77 percent.
    I love this phone and so happy I have one with a good battery!!! The Rep at Verizon was awesome, even gave me his direct line. I was able to exchange at local Verizon store which was nice since I bought online. Although I'm not sure the store reps believed me that the battery wasn't so good on the first one.
    Anyway, looking forward to a long (hopefully) future with this Maxx!
    Sent from my DROID RAZR using Android Central Forums
    bradenfontaine likes this.
  2. #2
    anthony2558's Avatar
    Posts
    Global Posts
    942 Global Posts
    ROM
    Stock
    Default Re: On second Max......battery is much better
    Glad it worked out.
  3. #3
    Congrats! This is good to hear. I felt bad for ya when you were having issues.
  4. #4
    Wow! Your battery is killer.good for you! Mine is good but nothing like that. Hmmmm.... Maybe I need a new one?
  5. #5
    bradenfontaine's Avatar
    The Mad Man
    Posts
    Global Posts
    2,233 Global Posts
    ROM
    Black Widow
    if you have any questions ill give you my direct line as well
  6. #6
    Default
    Stalker:-) haha
    Sent using Droid Razr Maxx
    Thanks everyone, y'all are so sweet
  8. #8
    The Mad Man
    Posts
    Global Posts
    2,233 Global Posts
    ROM
    Black Widow
    i didn't know they said "ya'll" in Chicago...
  9. #9
    Wow that's amazing battery life. Mine doesn't last that long. I can get a full day out of it but that's it.
  10. Thread Author  Thread Author    #10
    Well, technically, we don't, but I watched Dallas last night, so maybe that influenced me.
    Going on almost 10 hours and at 88%. Course I do have Smart Actions turn off data, etc. during the day. I don't know that I could get that using it more. The Verizon rep said his goes 3 days on 4G and using mobile hotspot. I think he was full of it personally....
  11. #11
    Default
    Quote Originally Posted by bradenfontaine View Post
    Me neither. I thought that was just us hillbillies in Southern Illinois.
    I don't care what kind of phone you use, that's not how I judge someone's worth or intelligence. Sent using tapatalk 2.
  12. #12
    I can get 10, maybe 12 hours of constant use out of my Maxx and it goes from full charge to nearly dead. Maybe I should call Verizon about it....
  13. Thread Author  Thread Author    #13
    Default
    12 hours of constant use? That sounds good to me. I doubt mine would last much longer if I was constantly on it. But maybe I'm wrong.....?
  14. #14
    Default
    OK, maybe it's good then. There are so many variables between one user and the next that it's very difficult to compare.
    Sent from my DROID RAZR using Tapatalk 2
  15. #15
    Quote Originally Posted by VTX1800N1 View Post
    What do you mean by constant use? Is your screen on constantly? Is 4G on constantly? If so, 10-12 hrs is pretty awesome. Most other phones would be lucky to go for about 4-6 hrs of constant use before needing a recharge.
    Here's an article from Time back in Feb, where a tech writer did his own informal testing. He found that the battery was exhausted after 4 hours of continuous 4G video streaming (which is clearly battery intensive); however, with the screen on constantly (and apparently not doing anything else), the battery lasted for almost 24 hrs.
  16. #16
    Quote Originally Posted by B. Diddy View Post
    Maybe about 70% screen on time. I don't have a 4G signal at my house (I'm on the fringe area and never get it here, even outside), but I do have 4G turned on. All data and background data always turned on. FB updates every hour. Gmail push, corporate email checking every hour, Accuweather updates every half hour, etc...
  17. #17
    So with all of that, your battery life is pretty darned good. First of all, I believe having 4G turned on in an area with intermittent or no 4G signal can contribute to increased battery usage, because the 4G LTE radio is constantly searching for a signal. Where I work, Verizon's reception is pretty poor, and I notice increased battery drain unless I switch the phone to Airplane Mode, because the phone is constantly searching for that signal.
    Second, the more frequently you set your apps to update, the more battery they use, because the apps are essentially waking the phone up to access the web.
    Since your area has poor or no 4G reception, you may want to change your radio to look for CDMA (i.e., 3G) only, rather than the CDMA/LTE mode. Go to Settings->Wireless & network settings->Mobile networks->Network Mode, and change it to CDMA only. Of course, when you go to other areas with 4G, you could change it back to CDMA/LTE. Not sure if Smart Actions can do this for you, since I never use it--anyone else know?
    In any case, don't worry--your battery's good!
  18. Thread Author  Thread Author    #18
    Default
    How do you change frequency of syncing apps?
  19. #19
    Quote Originally Posted by hazelgreen View Post
    It's usually in the Menu of the app. For instance, with Facebook, hit the Menu button, select Settings->Refresh interval, and select whichever interval you prefer. If you pick "Never," then it will only refresh when you manually do so (typically by dragging down on the main screen).
    For Gmail and other Google apps like Calendar on my old Droid Incredible, I remember being able to go to the phone's Settings somewhere and selecting whether I wanted them to update automatically or only when I manually wanted to update; however, I can't seem to find that selection screen on the Maxx. My phone is still set up to update only manually, though, so I think it was something I could select when I was initially setting up the phone and linking it with my Google account.
  20. Thread Author  Thread Author    #20
    Default
    Thanks.
  21. #21
    Ok, thanks to some posts in another forum, I figured out how to access the settings menu on the Maxx where you can disable automatic sync for Google apps. No idea why Motorola made this nearly inaccessible, whereas it was easily reached on the Droid Incredible.
    First, go to Settings->Data Manager, and uncheck Background data. Hit Ok when it asks you if you're sure.
    Then open Google Play. It will tell you you need to enable Background data. Hit "Enable," and you will be taken to the hidden settings menu. Make sure Background data is checked, and then you have the option of checking or unchecking Automatic sync--you can also select which features are automatically synced or not.
    Remember, if you choose not to automatically sync, you can still manually do so using the Toggle: Power Control stock widget or other 3rd party widgets like Power Controls.
  22. #22
    I'm thinking about switching from the iPhone 5 to the droid razr max for the bigger screen and the battery. Any thoughts?
    Sent from my iPhone using Tapatalk
    Douglas Wilson
  23. #23
    Quote Originally Posted by douglaswilson View Post
    Honestly, if you really want to switch to a RAZR, go with the new HD versions. HD screens, same battery size in the Max HD version but a more energy efficient processor means battery will last even longer than the maxx's we have. If you want their battery testimonials, head on over there and ask.
    Sent from my DROID SPYDER using Android Central Forums
    Thanked by:
  24. #24
    Actually I made a mistake- I left the HD off the name. That's the one I'm thinking about getting. Bigger screen and battery is all I'm thinking about.
    Sent from my iPad using Tapatalk HD
    Douglas Wilson
  25. #25
    When you think about it, it's not really a bigger screen. Sure, it's 4.7", but the screen has on screen keys that take up some of the screen. So the usable part of the screen, that would actually have stuff on it, that is not the home, back, settings, key is about the same.
