Results 1 to 7 of 7
- 06-17-2012, 11:50 PM
Thread Author #1
Disable Led Notification???
Is there a way to disable led notifications?
I would like to find a quick and easy way to disable the led notification light when I go to bed at night.
Sent from my DROID RAZR using Tapatalk 2 - 06-18-2012, 12:45 AM #2
Not that I can find in the stock settings. u may want to try led flow lite. It may be able to do what you want.
via Razr MAXX - 06-18-2012, 07:00 AM #3
Re: Disable Led Notification???
Light Flow should do what you want - though I have the paid version. There is a setting that you can enable that automatically switches off notifications while the phone is charging (assuming you charge your phone while sleeping).
- 06-18-2012, 07:11 AM #4
- 06-18-2012, 10:33 AM #5
- 07-20-2012, 06:37 AM #6
- 07-21-2012, 07:20 AM #7
Reply
