DEAL OF THE DAY: Save 60% on the LLOYD Flex Case for LG Nexus 4!
Page 1 of 2 12 LastLast
Results 1 to 25 of 26
Like Tree6Likes
    matthewjoseph255's Avatar
    Posts
    ROM
    standard
    Default Think i found a fix for network dropping problem..
    I have been testing this out for the past two days I booted into recovery and cleared my cache and i havent had any signal drops it worth a try report back and tell me how it works for you
  2. #2
    Johnly's Avatar
    Posts
    ROM
    AOSP, & stock.
    Default Re: Think i found a fix for network dropping problem..
    Oh snap....thank god.
  3. #3
    Default
    I never knew the cache could effect your signal. Interesting.
    Sent from my DROID RAZR using Tapatalk 2
  4. #4
    jeverts's Avatar
    Posts
    ROM
    Fission 2.5.7BE
    Default
    How does one boot into recovery on a non rooted razr? Thanks
  5. #5
    NickA's Avatar
    Posts
    Global Posts
    2,177 Global Posts
    ROM
    Stock
    Default
    I didn't know this was an issue on the RAZR. At first I thought I was in the Galaxy Nexus forum.
    Sent from my DROID RAZR using Android Central Forums
  6. #6
    Default
    Quote Originally Posted by jeverts View Post
    Turn phone off.
    Hold both volume keys and turn on device.
    Press down and highlight recovery and press up.
    You'll see android icon with triangle. Press both volume keys and highlight clear cache and press power button.
    Sent from my Droid Razr Maxx
  7. #7
    Sweet. Doing this now although I haven't seen many issues in my area. Austin.
  8. #8
    bradenfontaine's Avatar
    The Mad Man
    Posts
    Global Posts
    2,232 Global Posts
    ROM
    Black Widow
    Default
    Keep me updated as mine is having issues again.
    Its structural perfection is matched only by its hostility.
  9. #9
    10001110101's Avatar
    Posts
    Global Posts
    391 Global Posts
    ROM
    There will be many...
    DIdn't fix the issue on mine. ICS radios held data with no issue, but now that I'm back on 2.3.6 for the (hopefully) impending update my data sucks again.
  10. #10
    jeverts's Avatar
    Posts
    ROM
    Fission 2.5.7BE
    Default
    Thank you ewing
  11. #11
    Thanks to the op for posting. I tried this and will see how it goes, so far so good. Curious tho as to what is cleared by doing this. What sort of info is in that cache? Apparently a normal restart doesn't clear any of it.
  12. Thread Author  Thread Author    #12
    Posts
    ROM
    standard
    aw it was worth a shot lol.. my network hasnt dropped since will see if that changes it gets very annoying.... I am hopeing ics will change that before I get my galaxy s3 when it gets shipped
  13. #13
    I'll watch my data here but only thing I noticed right away was that the boot sequence to the home screen was much faster than it has been lately. Liked that
  14. #14
    Default
    I was having same problem. Tried a app called signal booster. Not sure how it works but it fixed my drop signal problems
  15. #15
    Quote Originally Posted by marcbutler1 View Post
    Thanks for this app tip. I tried it yesterday and it has def helped my at home signal issues I was having. On 3G I would lose signal a lot, only at home, just the area I'm in. This has really helped. Awesome! Gonna give it a couple more days then support the dev with some $.
  16. #16
    jeverts's Avatar
    Posts
    ROM
    Fission 2.5.7BE
    Default
    I tried it and it seemed to help only for 3G
  17. #17
    I don't have 4G yet. Hafta see how it does on it. As for my 3G it seems to help quite a bit at home where I would drop signal.
  18. #18
    Which signal booster app did you use? link? I found several but if yours worked I'd rather use that one.
  19. #19
    McIrish's Avatar
    Posts
    Global Posts
    81 Global Posts
    When I first started reading about network dropping, I thought everyone was crazy or had some misbehaving app. But in the last couple days, I've lost 3G and 4G and found the only way to get it working again was to pull the battery. I missd a lot of important emails while it was down. I sure hope ICS fixes this.
  20. #20
    Dovahkiin's Avatar
    One Man Wolfpack
    Posts
    Global Posts
    1,001 Global Posts
    ROM
    Stock
    Quote Originally Posted by McIrish2 View Post
    What?
  21. #21
    I thought the battery was sealed on the Maxx?
  22. #22
    The Mad Man
    Posts
    Global Posts
    2,232 Global Posts
    ROM
    Black Widow
    Default
    Quote Originally Posted by kingmeow View Post
    It is...
  23. #23
    Quote Originally Posted by Dovahkiin View Post
    What?
    There is way to simulate a battery pull. Press the power and volume down button for ten seconds.
  24. #24
    Default
    Thank you ewing
    No problem
  25. #25
    McIrish's Avatar
    Posts
    Global Posts
    81 Global Posts
    Quote Originally Posted by barrytest View Post
    Sorry, I meant the simulated battery pull. I shouldn't type when I'm asleep.
