Results 1 to 2 of 2
    freyr3333's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Question Calendar Help, Yep. I'm not very tech savvy
    Hey everyone.
    I was hoping someone can answer my question. I just purchased a Droid RAZR MAXX when my old Droid died after 3 years. With my old phone, calendar events on my phone calendar and Google calendar were automatically synced. Now with my new phone, calendar changes I make on my phone don't appear on my Google calendar on my computer, and vice versa. I tried syncing the accounts in my phone calendar, and it says the phone calendar is not synced, but it is visible. No matter what I do, I can't sync it. After that whole ordeal I checked out the Google calendar help page and it says to download Google Calendar Sync. Well, I am having problems with this. I am using a Mac for a computer, and every time I try to download Google Calendar Sync, the program Text Edit tries to open it (and it can't). I have an option to open the download with another program, but I don't know which one to use. I've tried several on my computer, but to no avail. Basically my question is what program do I use to open the download Google Calendar Sync? This is a very "beginner" question, but answers or help would be greatly appreciated.
    Thanks much!
  2. #2
    cmoore2004's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    It sounds like you downloaded the PC version. You'll need Windows to open it. I'm not sure if they even make a Mac version.
    For your actual problem with the calendar, you may just be viewing and adding events to the internal calendar. I set all of my stuff to go on my Exchange calendar.
    Sent via Tapatalk from my Razr Maxx
