1. Froalskiner#WN's Avatar
    I used to use my laptop usb port but it doesn't work with anymore. Just an FYI
    Sent from my DROID RAZR using Tapatalk 2
    06-30-2012 04:28 PM
  2. PeteK01's Avatar
    Works for me...
    06-30-2012 04:33 PM
  3. B. Diddy's Avatar
    Mine charges via USB off the laptop. Maybe try a soft reset/battery pull?
    06-30-2012 04:34 PM
  4. fatboy97's Avatar
    My USB cable with my PC works just fine to charge or move files to my SD card... and I've been using ICS for over a week now.
    06-30-2012 04:36 PM
  5. rcbjr2's Avatar
    Has anyone noticed that the "connect for charging only" option seems to be missing? Now it's only Mass Storage, Media Device, and Camera. Is there any way to get the "charging only" option back? I connect to USB at the office but just want to use it for charging because I'm concerned our systems might tried to encrypt my USB card. I could plug it into the wall I suppose, but I've been using this setup for years, and this way the phone sits right next to my monitor. Thx.
    07-05-2012 09:07 AM
  6. rbess1965's Avatar
    Yep. Noticed that. Mine still charges but I liked the option to select charging only after using it in mass storage. I felt like it was a safer way to eject the plug. Oh well. No issues with it so far.
    Message brought to you by the amazing Droid Razr Maxx
    07-05-2012 11:13 AM
