Results 1 to 5 of 5
- 07-17-2012, 10:08 PM
Thread Author #1
Sudden Signal Problems??
My signal has been fine since I got the phone, and just as fine since I upgraded to ICS. But starting yesterday, I noticed my battery draining like crazy, and I pinned it to having no signal for 20% of the time off charge. I thought this was insane. I use the LTE On/Off Switch because I don't have good LTE in my house, but I have decent 3G. That's when I noticed I was on 1X.
I've been playing with it today and it's a similar tale. All day at work, I was on LTE and was fine. I was getting around -65 to -75dBm on LTE. Since I've been home though, my battery started draining and I'm checking it now and I've got -100dBm on 1X and (if) 3G shows up, it's around -120dBm. I swear this wasn't the case two days ago or farther back.
Any ideas?
I've rebooted and cleared the cache partition for what that's worth. I just did a factory reset last week. - 07-17-2012, 10:36 PM #2
Try the “restore connectivity settings" application from Motorola in the play store
Sent from my DROID RAZR using Android Central Forums - 07-18-2012, 07:46 AM #3
- 07-18-2012, 08:10 AM
Thread Author #4
Re: Sudden Signal Problems??
I've had the RILD problem before, so I knew what to look for. This wasn't the case. Normally I reboot and RILD goes away.
I'm trying the Restore Connectivity Settings app now, but I won't be able to notice until I get home because I get perfect 4G connection at work. I'm worried it won't do much because it specifically says it's for 4G and 4G isn't my problem, 3G is. I COULD just simply turn data off at home since I have wifi, but my worry is that it won't connect to 3G anywhere and I'm going on vacation in 2 days and would like to have the capabilities of at least 3G on my 13 hour drive, haha. - 07-18-2012, 09:09 AM #5
Reply
