Results 1 to 9 of 9
- 08-02-2012, 12:09 PM
Thread Author #1
What is draining my battery?
Nothing but problems ever since the ICS "upgrade"
Now my battery seems to drain for no apparent reason fairly rapidly. I have background data turned off the only way you seem to be able to via ICS. (Into Data usage then set limit then restrict background data.), but my phone eats the battery like there is no tomorrow now & it sits on my desk all day hardly being used.
No, I have not added any new apps or programs. I am doing the same things I have always done.
Anyone else have this problem? - 08-02-2012, 12:27 PM #2
There has been multiple posts of horrible battery life with ICS. I for one have noticed a decrease as well, but not one as drastic as yours. There are some options for you tho, so you may be in luck. You can. Do your standard soft reset. You can install the. 215 leak (solved my issue). Factory data reset. (last option). If you live in an area with weak 4G install LTE on/off from the market and leave your phone in 3G only. Give some of those items a try, hope something helps you out.
You'll never take my unlimited data! - 08-02-2012, 12:31 PM #3
Re: What is draining my battery?
Make sure your network connection is not on "Global" cause that's what it was set to as default when the upgrade occured. So switch it to CDMA/LTE first. If that's done, try what anthony suggested.
- 08-02-2012, 02:20 PM
Thread Author #4
- 08-02-2012, 04:14 PM #5
How long have you had it charging? If it went all the way to 0%, let it charge for at least a half hour before trying to turn it back on.
- 08-03-2012, 07:02 AM #6
I had that with Maxx #2. Get rid of the phone.
Possum Pete
I'm Not Dead!
Galaxy Note 2 - 08-03-2012, 08:03 AM #7
Probably not what you want to hear but the factory reset drastically improved my batt life on Razr.
- 08-03-2012, 09:40 AM
Thread Author #8
- 08-08-2012, 09:06 PM #9
Reply
