1. Casey Cheung's Avatar
    Verizon level 2 tech support has decided to give me a like-new refurb Verizon Razr Maxx to replace my Verizon Thunderbolt due to having data connectivity problems for many weeks. I just want to know if you Razr Maxx owners are having data/internet connectivity problems too, or if everything is generally okay? Thanks! Casey
    08-06-2012 10:19 PM
  2. B. Diddy's Avatar
    You're in SF? I'm in Sunnyvale. I haven't had any 4G problems in the South Bay, except in areas that are known black holes anyway. There's an app called Coverage Map which can give you an idea of voice and data signals in your area, based on crowdsourcing. Check it out here:
    https://play.google.com/store/apps/d...90bWV0cmljcyJd
    08-06-2012 10:27 PM
  3. Casey Cheung's Avatar
    Yes, I'm in San Fran, which is generally a major 4G area. But for past several weeks or longer, my Thunderbolt has been acting strangely with poor data/internet connection. It's not just me either, as a number of Thunderbolt users are complaining of the same thing. I'm not sure if it's a device issue or a Verizon carrier issue. I will receive a refurb Razr Maxx in a few days, so hopefully the Razr will have better connection, fingers crossed!
    08-06-2012 10:52 PM
  4. dragonsamus's Avatar
    Sometimes my data goes out but it's not often like the thunderbolt.
    08-07-2012 03:16 AM
  5. hakimmmmm's Avatar
    My 3g connection disconnects for a minute then reconnects and it happns often
    Sent from my XT910 using Tapatalk 2
    08-07-2012 08:05 AM
  6. LegalAmerican's Avatar
    My data connectivity is flawless in Utah and i'm not in a fantastic 4G coverage area.
    08-07-2012 09:37 AM
  7. LdotAdot13's Avatar
    I'm in the Chicagoland area with great 4G and I have been losing data.
    Sent from my DROID RAZR using Android Central Forums
    08-08-2012 08:53 AM
  8. gymgal1951's Avatar
    I'm in St.Charles countyside, Illinois. Suburb of Chicago. I have had excellent 4g coverage, 5 bars 99% of the time. Occasionally, data hangs, but no longer than 1-minute, during peak hours.
    08-08-2012 09:00 PM
