Page 1 of 2 12 LastLast
Results 1 to 25 of 34
Like Tree5Likes
    pauliphone5's Avatar
    Posts
    Global Posts
    2,563 Global Posts
    ROM
    ICS 4.0.4
    Default Signal, switching between 3G and 4G LTE
    I have to say, one thing that I am not impressed with on the Maxx is the problem with the phone switching between 3G and 4G LTE. I purchased this phone for my gf a couple of months ago. The worst part of it is that when it does switch, it drops whatever phone call you are on.
    It seems like they never really solved the problem since the Droid Bionic was released. It isn't as bad as it was on the Bionic, but it is definitely still there. It is too bad too, the phone is a decent phone other than that. I'm really disappointed in Motorola not solving this problem.
    Sent from my Verizon Galaxy Note 2, Verizon Galaxy S3, or N7, or MacBook Air
    chevyman29 likes this.
  2. #2
    carracerz14's Avatar
    Posts
    ROM
    Arctic HD
    Default
    I don't have any problem. Maybe it's your area.
    Sent from my RAZR MAXXIMUS
    Posts
    Global Posts
    2,563 Global Posts
    ROM
    ICS 4.0.4
    Default Re: Signal, switching between 3G and 4G LTE
    Quote Originally Posted by carracerz14 View Post
    I guess that is possible. But, I don't have that problem with the Galaxy Nexus, or S III.
  4. #4
    Default
    I have this problem, called Verizon and they said I should have full signal. They had me take Sim card out for five minutes and turn back on, said would download new PRL. did that and still no good.
    Sent from my DROID RAZR using Tapatalk 2
  5. #5
    Posts
    ROM
    Arctic HD
    Default
    Try getting a new sim card then
    Posts
    Global Posts
    2,563 Global Posts
    ROM
    ICS 4.0.4
    It isn't the sim card. I've switched out the sim with three other micro-sim's that I have for other devices that work perfectly.
  7. #7
    Posts
    ROM
    Arctic HD
    Default
    Then get a replacement.
  8. #8
    Switching between 3G and 4G eats up alot of battery, too. When I'm on wifi the power barely goes down. At work, I start in 4G and it flucuates between that and 3G and sometimes drops out completely. Meanwhile, the battery is draining faster than the kitchen sink. Keep the power cord handy!
    Possum Pete
    I'm Not Dead!
    Galaxy Note 2
    Posts
    Global Posts
    2,563 Global Posts
    ROM
    ICS 4.0.4
    Quote Originally Posted by PossumPete View Post
    i'm not too worried about the battery. I've always got a power supply for my phones. I think at this point, I'm more disappointed and somewhat miffed because it seems to me like Motorola, a company that is supposed to know their radios still can't seem to get this one fixed.
  10. #10
    jeverts's Avatar
    Posts
    ROM
    Fission 2.5.7BE
    Default
    Mine does the same thing, been living wirh it, very annoying, I've flashed the 215 also, didn't make a difference. Stupid effin phone!
    pauliphone5 likes this.
  11. #11
    jeverts's Avatar
    Posts
    ROM
    Fission 2.5.7BE
    Default
    I had a DX prior and had it rooted, oc and romd. My biggest regret is not getting the g-nex, there is just almost nothing out there regarding kernals and roms for this device. I also have a GN7 tablet rooted and romed that is flawless and lightning fast. Never again will I go with a locked bootloader, lesson learned here.
  12. #12
    bradenfontaine's Avatar
    The Mad Man
    Posts
    Global Posts
    2,233 Global Posts
    ROM
    Black Widow
    i honestly wonder if its not something on Verizon's end... according to the Cell Phone Coverage Map app i'm getting better signal than most people report. but in the really bad areas i will fluctuate.
    If i have ever helped you, please do not forget to hit Thanks
    If you ever have any questions about rooting we have written up a nice little thread HERE, please read this and post if you have any questions.
    If you need directions on how to clear your Cache, i have a write up HERE
  13. #13
    jeverts's Avatar
    Posts
    ROM
    Fission 2.5.7BE
    Default
    The frustrating part is, most if the time I'm in a strong 4g area and the speed is very fast, still it switches back and forth.
  14. #14
    The Mad Man
    Posts
    Global Posts
    2,233 Global Posts
    ROM
    Black Widow
    are you rooted?
  15. #15
    jeverts's Avatar
    Posts
    ROM
    Fission 2.5.7BE
    Default
    No, other than the 215 patch, stock ics
  16. #16
    The Mad Man
    Posts
    Global Posts
    2,233 Global Posts
    ROM
    Black Widow
    care to root? i had similar issues before i rooted, and now that i am rooted with a custom ROM, i do not. if it is software based then yes Moto needs to fix it. it very well may be. i don't think it is hardware based because i changed my software and the problem went away. i take back what i said about it being a Verizon issue.
  17. #17
    jeverts's Avatar
    Posts
    ROM
    Fission 2.5.7BE
    Default
    Yea, maybe I'll give it a go. What ROM you using?
  18. #18
    The Mad Man
    Posts
    Global Posts
    2,233 Global Posts
    ROM
    Black Widow
    many people are enjoying the Arctic ROM, im on Black Widow. ill post links in a few
  19. #19
    The Mad Man
    Posts
    Global Posts
    2,233 Global Posts
    ROM
    Black Widow
    Arctic...
    and Black Widow...
  20. #20
    jeverts's Avatar
    Posts
    ROM
    Fission 2.5.7BE
    Default
    Thanks man, much appreciated...
    bradenfontaine likes this.
  21. #21
    jeverts's Avatar
    Posts
    ROM
    Fission 2.5.7BE
    So, is the ArticBetaSemiFinal.zip the latest?
  22. #22
    Posts
    ROM
    Arctic HD
    Default
    Quote Originally Posted by jeverts View Post
    I think artic 215 is the latest. You can flash it right over stock ics. 215. Just remember to use safestrap
  23. #23
    jeverts's Avatar
    Posts
    ROM
    Fission 2.5.7BE
    So, is the ArticBetaSemiFinal.zip the latest? Nevermind, got it...
  24. #24
    The Mad Man
    Posts
    Global Posts
    2,233 Global Posts
    ROM
    Black Widow
    read up on safestrap and what it does, helps to have a better understanding of why you are doing it before you do it.
  25. #25
    The Mad Man
    Posts
    Global Posts
    2,233 Global Posts
    ROM
    Black Widow
    also download Matt's 1.8 utility, makes life a little easier
