Results 1 to 3 of 3
- 09-05-2012, 01:08 AM
Thread Author #1
Weather widget problems
I've been downloading and trying out a lot of weather apps and widgets this past week and I decided to give the default/stock weather widget a try, but for some reason I can't get it to work with Nova Launcher Prime. I can add the widget to my home screen, but it will just be stuck on the loading symbol thing. It will successfully load and be interactive when I add it to one of the home screens on the stock launcher. Anyone know if there's a solution to this problem? Thanks a lot guys!
Sent from my DROID RAZR using Android Central Forums - 09-05-2012, 12:47 PM #2
Re: Weather widget problems
I don't use the stock weather app, but do use Beautiful Widgets... (BW for short)... BW did an update last week and said they removed Google's Weather because Google had made some change to their Weather API. Anyways, that might be the issue, and if it is you might want to look at some other app.
The nice thing with Beautiful Widgets is they use more than just Google Weather, but right now they only have Accuweather... which works great by the way, at least in my area. I've never heard anyone complain.Droid Razr Maxx
HTC Thunderbolt (Retired)
HTC myTouch 4G (Retired)
Blackberry's 8900 to Bold (Retired)Flames Wallpaper
Jerry: "Love, Peace, and Chicken Grease!!!" - 09-05-2012, 07:39 PM
Thread Author #3
Reply
