1. droidntn's Avatar
    I usually wall outlet charge Maxx. But I left him on the usb charge the other night and it seemed like it had more charge left at the end of the day.
    Is there a difference?
    Sent from Marx Maxx
    09-10-2012 06:26 AM
  2. cyanogen-man's Avatar
    Deff wall outlet most USB ports are regulated to set a lower voltage so it don't fry the battery
    INSPIRE AOKP ICE COLD SANDWICH ROM
    09-10-2012 07:10 AM
  3. Ry's Avatar
    Sent from Marx Maxx
    Not sure what you're trying to say here.
    USB charge via computer? I think those max at 500 mAh.
    Wall chargers can vary.
    Sent from my DROID BIONIC using Android Central Forums
    09-10-2012 11:34 AM
  4. droidntn's Avatar
    I'm saying I charged it via the included charging/data cable on a USB port on a computer.
    compared to charging it on a 110 outlet charger.
    - - - Updated - - -
    09-10-2012 11:43 AM
  5. Ry's Avatar
    Could have been you just used it less that day...
    bradenfontaine likes this.
    09-10-2012 11:51 AM
  6. bradenfontaine's Avatar
    Wall charger pumps more juice than via a PC. If anything it would just take longer to charge, but that doesn't translate to a longer charge buddy.
    sent from the fingers of a madman
    BradenFontaine@gmail.com
    09-11-2012 08:03 PM
  7. carracerz14's Avatar
    Usb charges slower than wall, usb puts out less power. Fact.
    Sent from my RAZR MAXXIMUS
    09-11-2012 09:39 PM
  8. Eclipse2K's Avatar
    And while using the mobile hotspot, my phone would charge on the wall but stay the same on USB. Not very productive if you ask me.
    Sent from my DROID RAZR MAXX using Tapatalk 2
    09-11-2012 09:58 PM
  9. carracerz14's Avatar
    Yeah it's because the usb can't keep up with the rate of discharge if you are doing something that uses a lot of power, like hot spot.
    You can make usb charge as fast as AC by using fast charge, available in some roms, but I don't think it's too good for your battery
    09-11-2012 10:52 PM
  10. dpham00's Avatar
    usb 2.0 spec is 5v/500ma max
    typically smartphone chargers are 5v/1A.
    tablets are typically 5v/2A.
    oddly, when i tried to charge my Maxx using my tp charger, it would only do so at 5v/500ma. but using standard smartphone chargers, it would do 5v/1a.
    09-11-2012 11:16 PM
  11. bradenfontaine's Avatar
    ...oddly, when i tried to charge my Maxx using my tp charge...
    tp... you have a toilet paper charger? is that some new hipster thing? id love to get one for my sister, she'd love that sh!t.
    carracerz14 likes this.
    09-12-2012 07:19 AM
  12. droidntn's Avatar
    Well sounds right.... Technically.
    All I know is when I take it off wall charger, same time as usb charge overnight, it says 99%.
    Usb charge overnight says 100%.
    Approximately same use, end of day is about 15-20% more if charges on USB.
    Just sayn....
    Sent from Marx Maxx
    09-12-2012 10:02 AM
  13. bradenfontaine's Avatar
    09-12-2012 11:15 AM
  14. carracerz14's Avatar
    Just sayn....
    Sent from Marx Maxx
    Usb won't increase the capacity of your battery Lmao here have a :beer: on me for the creativity though
    09-12-2012 11:46 AM
  15. droidntn's Avatar
    I'll take it! :beer:
    Thanks. So....okay.
    The difference I see on my screen is all in my mind as in a movie.
    *whisper * I see dead people and better battery charges on my USB.
    Sent from Marx Maxx
    09-12-2012 12:30 PM
  16. NinerJet9's Avatar
    I recently switched from the stock wall charger to a Belkin triple outlet + usb socket. That gives me 100% charge every time.
    09-13-2012 11:46 AM
  17. bradenfontaine's Avatar
    ಠ_ಠ
    09-13-2012 12:45 PM
  18. dpham00's Avatar
    Touchpad.
    droidntn likes this.
    09-13-2012 05:18 PM
  19. scotts9219's Avatar
    Amperage is the main thing when you are charging a battery. Due to the circuitry in the Li-Ion battery, you are generally safe using USB, 1A, or 2A charger. My rule is the charger should not be more powerful than the battery (i.e., 2A charger max on a 2000mA battery). If the battery is charging too fast the logic on the battery will shut down the process to keep the battery from overheating. Heat is the number 1 killer of Li-Ion batteries. If you're charging your phone and it seems to get a lot hotter than normal when you charge it you might want to go to the next step down size charger since it will eventually cause the battery to wear out faster. BTW, cases are a bad idea when it comes to batteries. They were not part of the original design spec and usually cause the battery to get hotter than intended.
    The charger that comes with our Maxxs' are 750mA so a mostly drained battery (almost impossible to totally kill a battery) will take about 4 hours to charge. Using a 1A charger takes that number to 3 while running amok with a 2A charger will 1.5 hours. These are approximate times but I've used the 2A option several times without any issues. Since I usually charge my battery overnight I just use the stock charger and we're charged by the time I get up - unless I was up all night. Keep in mind, these times are based on an idle or off phone. Using the phone on the charger will lengthen these times.
    Just my $.02
    09-14-2012 10:04 AM
  20. dpham00's Avatar
    I tried to use a 2a charger on my razr maxx and it would only charge at 500ma. Which 2a charger did you use?
    09-14-2012 09:58 PM
  21. scotts9219's Avatar
    I use a (gasp) Blackberry Playbook charger. I carry it with me most of the time and use it when on trips.
    09-17-2012 08:53 AM
  1. Which Voice Recognition is Better - ICS on the GN or iPhone 4S?
    By CarryMe in forum Verizon Galaxy Nexus
    Last Post: 12-23-2011, 06:18 PM
  2. No charge on USB/12v outlet?
    By bigunclephil in forum HTC EVO 3D
    Last Post: 09-08-2011, 08:52 PM
  3. Replies: 9
    Last Post: 08-25-2010, 04:18 PM
  4. Better AT&T service on your N1 or iPhone?
    By luckydwg in forum Google / HTC Nexus One
    Last Post: 03-24-2010, 08:35 PM
  5. Slow charging on USB?
    By kehanra99 in forum HTC Hero
    Last Post: 12-05-2009, 03:02 PM
